Oil & Fuel MT2201d fill and drain plugs
/ MT2201d fill and drain plugs #1
larry154
Hi, I just bought a used 1989 gray scale Mitsubishi MT2201d. I have a couple of questions.
1. Is the gear oil "check plug" on the right side bottom of the motor.?
Above the "drain plug" on the side. One above the other.?
2.Is the small rubber plug between the shifters the "fill hole" for the gear lube.?
3.What is the small box on the left side front panel.? I feels like a variable switch.
4. Would 80wt-90wt GL5 gear lube be good for this.?
Some heavy oil came out of the drain plug. 6 qts. or so.
I ordered a manual for it but would like to get the fluid changes done now.
Thanks for any help on this.
Larry154
/ MT2201d fill and drain plugs #2
Valley Power
search this site you may find something you need.your manual would specify the oils.you can call the number on the site and make inquiries.
OK, thanks Mit. I will try that.
2015 WESTERN STAR  4700 SF DAY CAB (A60736)
2015 WESTERN STAR...
2019 Ford E-450 Shuttle Bus (A61568)
2019 Ford E-450...
2025 GIYI GY-PG72C 72in Dual Cylinder Hydraulic Grapple Bucket Skid Steer Attachment (A61567)
2025 GIYI GY-PG72C...
2017 ADDCO ROAD SIGN DH1000-ALS (A60736)
2017 ADDCO ROAD...
2007 Chevrolet Suburban Multipurpose Vehicle (MPV), VIN # 3GNFC16097G214917 (A61165)
2007 Chevrolet...
2011 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A60736)
2011 DRAGON 150...
