mr. funnel
   / mr. funnel #1
Larry_T
wis
kubota L3010
it took me two wks to figure out this computer or i would have posted sooner. does it matter what one i buy conductive or non conductive? I don't know how you guys got names on here mine 3010 which is my tractor model. kubota
   / mr. funnel #2
301o
Welcome to TBN. /forums/images/graemlins/smile.gif
You want the non-conductive model.
The conductive is for Aircraft and Marine applications.
Actually your TBN name is the number 301 plus the letter O. /forums/images/graemlins/wink.gif
It works. /forums/images/graemlins/cool.gif
   / mr. funnel #3
301o:
Nothing wrong with a 3010 as far as I am concerned. Welcome to TBYNet.
On the Mr. Funnel......... and to Ron too, I bought the conductive one. I use it for diesel as well as gasoline. Get the high capacity one. Diesel will thicken a little in cold weather and the lower capacity funnel, well....you have to be pretty patient.
I guess you's be okay as long as your diesel is warm, but I fill off a bulk, outside tank. The diesel is cold in the winter.
   / mr. funnel #4
"does it matter what one i buy conductive or non conductive?"
Hey, welcome!
Actually, I think the most correct answer is NO, it doesn't matter. Either will do the same filtering job. The non-conductive is cheaper, but my experience was that the conductive model was easier to find, so that's what I bought. If I could have found the non-conductive one, I would have bought it and saved a couple of bucks.
I got the middle size (F3C), and have found it a good size for use with my BX23. It does take the fuel a while to pass through the filter, though, so the advice to get the bigger model is good, especially if you're filtering a lot of fuel. In my case, I only pour a couple of gallons at a time.
As was discussed here recently, Lake and Air, a seaplane pilot shop, has good prices and prompt response. You can find them by clicking HERE .
/forums/images/graemlins/tongue.gif
"Don't pack hardware for bluff or balance."
   / mr. funnel #5
Rimmer:
I purchased mine right from the manufacturer.
With all the hoopla about filling plastic gasoline cans at the gas station in the back of your pickup on the plastic bed liner and static electricity discharge and then "BOOM", I felt that the conductive one was a better investment. Again, I use mine for diesel as well as gasoline.
   / mr. funnel #6
Either one would work... what does a Mr Funnel do that a regular funnel doesn't do? Filter particulate matter? Separate water?
   / mr. funnel #7
</font><font color="blue" class="small">( what does a Mr Funnel do that a regular funnel doesn't do? Filter particulate matter? Separate water? )</font>
Yes to both questions.
UNUSED Tool Set (A53117)
UNUSED Tool Set...
2011 INTERNATIONAL PROSTAR TANDEM  AXLE MID ROOF SLEEPER (A54313)
2011 INTERNATIONAL...
ASCO Transfer Switch (A52377)
ASCO Transfer...
2011 TRAIL KING LOWBOY TRAILER (A50459)
2011 TRAIL KING...
2021 FREIGHTLINER M2106 DEBRIS BUCKET TRUCK (A51406)
2021 FREIGHTLINER...
2017 Nissan Frontier Ext. Cab Pickup Truck (A51692)
2017 Nissan...
