Mr Cool DIY Mini Split AC/Heat Pump
   / Mr Cool DIY Mini Split AC/Heat Pump #31
I have an LG mini-split 18K BTU does both heating and cooling. I installed it myself.
The local HVAC guys wanted ~$4k to install one. I bought one on-line with the vacuum pump and meter for a little under $2k. The hardest part on the install was holding the 35# indoor unit up in the air while my wife tried to guide the pipes thru a 3" hole.
We have about 900 sqft it's 24x36 with an enclosed bath at one end and a room divider (no door) for a 12x12 area at the other end. we have no problems with heat/cool in the bath.
The biggest problem for us is maintenance. As was mentioned, the coils have to be cleaned periodically. Ours is mounted 8' up on a 10' wall over the washer & dryer so we have to move those out of the way to get the ladder in for the tech to work on it. The tech won't move the appliances and we're getting old enough where it's getting to be difficult to do. We've had it up 3 years now and have had the tech in once to clean the coils and check it out. I also vacuum the drain line from the outside periodically to make sure it stays clear, otherwise you'll have water running down your wall. That's all it gets for maintenance.
   / Mr Cool DIY Mini Split AC/Heat Pump #32
I installed a DIY Mr. Cool 24,000 BTU mini split in my shop a little over a month ago. Works great keeps a 30x40 shop with 10' ceiling exceptionally cool. I have it set to 73 degrees and it has not had any trouble keeping the space very cool. The indoor head unit runs very quiet, the only way I know it is running is seeing the vent is open, the outside unit is very quiet. My wife has expressed her frustration that this unit is way quieter than our home central air system. Installation was not as difficult as I thought it would be. Best money I have spent on this shop.
   / Mr Cool DIY Mini Split AC/Heat Pump #33
Does your shop have windows? Roll-up doors? Blow-in insulation? How hot is your outside?
I'm considering getting one of these units for my 30x30 shop. My shop is a typical industrial-type metal building built from structural I-beam with metal siding. There is the white-backed fiberglass insulation. It has no windows. 11ft eaves, 15ft peak. One 10ftx10ft "Insulated" (looks like it has a radiant barrier taped to the inside) rollup door and a single man door. The building is color "polar white" which is supposed to reflect light/heat even better than regular white. I can see daylight around the rollup door. Probably need to do something about that before I expect any AC to perform well. I'm in Texas by the coast; the ambient temperature and humidity stays right at about Satan's ******* for most of the year, and because I only have a single rollup door, I can't even get a breeze through there.
Here's my concern: AC manufacturers probably spec their "good for _X_ sq ft" numbers on house-type spaces with reasonable insulation, attic space, etc.; not a structure built like a convection oven and with an extra 4 cubic ft of air per every square foot of floor space. I don't know the R-rating of my insulation but it's probably half what a house has, at best. So without any math or science at my side, I'm taking a stab in the dark and estimating that I need at least double the BTU as whatever a given AC MFG says I need. So I'm looking at the Mr. Cool 36k BTU for my shop. But then I keep running across examples (like yours) of people with bigger shops than I have, cooling it with smaller units, and having no issues. I don't want to over-spend, but I dang sure don't want to buy an A.C. that's too small and have to eat it and buy a bigger one the second time around.
What size would be recommended for my shop?
Also, I am having trouble wrapping my head around how a small unit mounted far away on one wall of the shop, which intakes and discharges air from the same spot, can cool all the hot air on the other side of the shop. Seems to me, most of the air it would be taking in, is the same air it just cooled. I don't understand how I or anyone could get away with anything but a ducted solution, where air is drawn in from one side of the room, cooled, and discharges somewhere else in the room. Do these things really provide cooling for the whole shop or would I need fans mounted all around to distribute/mix the air?
   / Mr Cool DIY Mini Split AC/Heat Pump #34
Our minisplit pulls air from the top of the ceiling and vents it out the bottom so you're cycling the hottest air into the coolest which will settle lower and is pretty efficient. Probably not as great for heat but works great as an AC.
   / Mr Cool DIY Mini Split AC/Heat Pump #35
Strantor, I'm in the same boat as you.. Metal bldg., hi roof, little insul.. For some reason, mine stays reasonably cool in the middle of the day, prob. because its tucked in the corner of the wood line.?? but in the winter, you can see your breath & cant feel your fingers..
Granted, it could always be cooler..
I've been following this thread also.. I recently ran across a listing on my local Craigslist from an a/c seller & installer.. selling guaranteed reman units. 1.5-2 &3 ton units for &1500. 1800.00-$2,000. INSTALLED w/ warranty..
& even an offer to come out to your shop/building & "spec out" what you need. size of unit, electr. needs & so-on..so you don't buy something unnecessary..
I just thought I'd throw that out there, incase you haven't thought about looking "there"..
That's prob. the way I'm leaning towards because like you, those "small" wall mount units are nice but scare the heck outa me.. as far as not putting out the air I want vs the money I spent.
   / Mr Cool DIY Mini Split AC/Heat Pump #36
Thanks I hadn't considered that. I'll look into it.
Well I ordered a Mr Cool 18k from Costco today, it will be a little while before I'm ready to install it but the price was right and hopefully I will have good luck with it, thanks, for all the replies. Charlie.
   / Mr Cool DIY Mini Split AC/Heat Pump #38
Mine came yesterday. This thread has sold two Mr. Cool 18k BTU units. My line set cover and wall mount are all I need to get started. They should be here this weekend from Amazon. I also still need to get a 3 1/2" hole saw bit.
   / Mr Cool DIY Mini Split AC/Heat Pump #39
I'm going to follow this. The 8000 btu unit we have in a window in the house would easily cool my shop and a new mini split would be awesome in the house!
   / Mr Cool DIY Mini Split AC/Heat Pump #40
I got one room upstairs on southwest (sunny side) that stays warmer. Thinking about a small one for it. I already have power disconnect outside that used to feed an outdoor unit before i put in geo.
2014 DRAGON 130 BBL STEEL VACUUM TRAILER (A55745)
2014 DRAGON 130...
FAKE (A52472)
FAKE (A52472)
378813 (A51573)
378813 (A51573)
2021 John Deere 6155M (A53314)
2021 John Deere...
2005 Ford F-150 Pickup Truck (A54814)
2005 Ford F-150...
Perkins 1791 Power Unit (A53314)
Perkins 1791 Power...
