Mpower 85 alarm
/ Mpower 85 alarm
@Navasot- You sir were 100% correct. We replaced the sensor and noise stopped. We just got done baling over 100 bales and tractor is running great! Thanks for everyone's input.
/ Mpower 85 alarm #22
Good deal! How does it pull the 347?
/ Mpower 85 alarm
I actually just sold that baler and we where using the MF 1745. That baler can eat some hay! We had a couple of issues but once we got them right, it worked perfect!
/ Mpower 85 alarm #24
Good deal it should handle that baler well
/ Mpower 85 alarm #25
I’m having this issue myself but haven’t located where the sensor is, any help will be greatly appreciated. I have the sensor on hand but not yet removed.
It’s on an mpower 85, open deck.
/ Mpower 85 alarm #26
I have also had an alarm after ~3 Minutes. I checked the coolant, engine oil, hydraulic fluid, and even threw an ODBII reader on it to see if I could get a diagnosis all to no results... everything looked good. So I googled the problem, got brought here, read the thread RE Scavenger Pump Sensor, and promptly ordered one. I went to install it today and found the 1st oil pressure sensor near the Battery Box but had read somewhere to lay down and look behind the battery box. To my surprise behind the battery box, I found an oil filter that had unscrewed from the tractor. I had the tractor recently serviced, I guess the tech was a little light with "hand tighten". My guess is that after some point (3 minutes for me) the tractor gets to the point where it needs oil filtered and when it kicks on the pump and then the sensor goes... "no, there's an issue" and kicks off the pump and kicks on the alarm.
So... STEP 1: Check all fluids AND filters... then everything else on the thread.
PALLET OF 51 X 41 X16 BRASS WEAR RINGS (A67714)
PALLET OF 51 X 41...
2016 Chevrolet Suburban 4x4 SUV (A66738)
2016 Chevrolet...
TWO PALLETS OF HYD TANK, V8 ENGINE BLOCK/PARTS (A68842)
TWO PALLETS OF HYD...
2009 IMPERIOAL DT7126T 12FT CUSTOM DUMP TRAILER (A66091)
2009 IMPERIOAL...
2019 KOHLER 38RCL Generator DISCONNECT ATS 38KW 315 HORS (A66734)
2019 KOHLER 38RCL...
2018 PETERBILT 567 FLATTOP SLEEPER TRK (A67714)
2018 PETERBILT 567...
