Mowing mowing
/ mowing #1
mrweekendfarmer
4066 john deere
have a 2015 JD 4044 that stalls when mowing with 72" rotary mower. oil and hydraulics are ok.
/ mowing #2
Did you check the air filter? When was it when you last changed the fuel filter? Did at some point fall anything in your tank that could cause a restriction that does not allow enough fuel to flow when the engine is under load? How does the engine handle any other load, like pulling a trailer up a hill?
/ mowing #3
mrweekendfarmer
:welcome: to TBN
Which rotary mower do you have? is it belly mower, or 3 ph mower?
And is the tractor a 4066R or really a 4044 ?
2016 Kia Forte Sedan (A61574)
2016 Kia Forte...
JOHN DEERE 1750 CONSERVATION 6R PLANTER (A63745)
JOHN DEERE 1750...
(3) STICKS OF 2" x 20' MILLING ROD (A63745)
(3) STICKS OF 2" x...
2006 Ditch Witch H313 Trencher Attachment (A62183)
2006 Ditch Witch...
2022 Belshe WB14 18ft  12000lb Trailer (A64047)
2022 Belshe WB14...
Pallet of Two Pivot Wheels & Tires (A62177)
Pallet of Two...
