Depends on type of grass, how thick, how tall, etc. 3043 rpm's is the official book answer. I personally mow my horse pastures between 3000-3100 rpm's.
My BX24 has a tech a WOT is not needed if you have proper blades sharpness etc...
My old BX22 was about 3/4 open throttle...aka 3000 rpms...WOT, in my eyes is not needed unless you are mowing a field 3 ft high with crap blades...:thumbsup::thumbsup::thumbsup:
I use 2800-3000 on my 2360. Also, mine reads 3400 not 3200 when wide open. There is another informative thread not too old debating the use of WOT or not.
I keep the blades sharp and the lawn is in very good shape...I just run it wide open...Helps throw the grass and has no ill effects...Been doing it for 7 years on 2+ acres of lawn....I wouldn't use the MMM on a field....
Suppose I could wind it back, but I really don't see a reason. If I remember correctly, the manual recommends WOT on my model when mowing. I don't do that when using the BH, I adjust the RPM's to the need.
Kubota M8540HDC, L5740HSTC, BX2200, BX2660, John Deere 425&1025R, Case, Massey Ferguson, Ford
There are at least two other threads not too old on this, I ran my 2200 WOT and my 2660 at about 3000, they are designed for high RPM and see no reason to cut back from manual recommendations.
