Mowing Mowing RPM
   / Mowing RPM #11
What these fellows said, plus closer to WOT will lead to better battery longevity for some folks, and keep the transmission a bit cooler in my opinion.
Sometimes, in conditions where rabbit speed would be appropriate, I opt for turtle, with WOT, and foot pedal to the floor. I do this because it is not that often I get to put the pedal to the floor, so I wonder about the piston bores in the axial piston pump. Edit...I forget to do this in reverse, so I ought to remember now, since I wrote it, and said it out loud too.*
Tell your kids a good learning technique is to think it, write it, and say it. Do that before bedtime the day before the test.
   / Mowing RPM #12
Good idea. Same pistions used tho, so unless you do a tremendous proportion of backing, just exercising in forward oughta do it. ... Not sure how much issue the different side thrust is.
larry
   / Mowing RPM #13
larry
Larry, in reverse, do you know right off if the pistons stroke a slightly different section of bore? I thought they do but I need to get another cup of coffee and think about it more.
Edit: Coffee was good. Thinking about it, forward swash plate angle is far greater than reverse, so reverse piston travel in reverse is contained as a subset of the forward piston stroke travel. Pressures should be different in reverse in that section of stroke than it would be in forward. It's a minor issue, but interesting.
Anyone not familiar with what goes on in that pump, and if you are willing to sit through a 30 second commercial, you can see PART of the pump internals here:
http://www.metacafe.com/watch/1606910/hydraulic_piston_pump_how_it_works/
Forestry Truck Grapple and Frame (A55852)
Forestry Truck...
UNUSED LANDHERO LDH-T460 STAND ON SKID STEER (A57192)
UNUSED LANDHERO...
UNUSED FUTURE FR70 70" HYD FLAT RIPPER (A57193)
UNUSED FUTURE FR70...
2005 EAST 45' WALKING FLOOR TRAILER (A57192)
2005 EAST 45'...
Frontier RC2060 (A56469)
Frontier RC2060...
Margaritaville Miniature Decorative Truck (A55853)
Margaritaville...
