Mowing Mowing RPM
/ Mowing RPM #1
warcloud
i have a BX 2360 with a 54" mower would like to know what rpm is best for mowing. i currently run about 2800 rpm max rpm is 3200
/ Mowing RPM #2
Depends on type of grass, how thick, how tall, etc. 3043 rpm's is the official book answer. I personally mow my horse pastures between 3000-3100 rpm's.
/ Mowing RPM #3
I do 2800 rpms since unless you are higher, seems a waste of fuel..
/ Mowing RPM #4
I don't have a tach on my BX23, so I mow at WOT...Works great and really doesn't use much fuel at all.
/ Mowing RPM #5
My BX24 has a tech a WOT is not needed if you have proper blades sharpness etc...
My old BX22 was about 3/4 open throttle...aka 3000 rpms...WOT, in my eyes is not needed unless you are mowing a field 3 ft high with crap blades...:thumbsup::thumbsup::thumbsup:
/ Mowing RPM #6
I use 2800-3000 on my 2360. Also, mine reads 3400 not 3200 when wide open. There is another informative thread not too old debating the use of WOT or not.
/ Mowing RPM #7
I keep the blades sharp and the lawn is in very good shape...I just run it wide open...Helps throw the grass and has no ill effects...Been doing it for 7 years on 2+ acres of lawn....I wouldn't use the MMM on a field....
Suppose I could wind it back, but I really don't see a reason. If I remember correctly, the manual recommends WOT on my model when mowing. I don't do that when using the BH, I adjust the RPM's to the need.
/ Mowing RPM #8
There are at least two other threads not too old on this, I ran my 2200 WOT and my 2660 at about 3000, they are designed for high RPM and see no reason to cut back from manual recommendations.
/ Mowing RPM #9
3,000 rpms on my BX2350 when mowing. Not for power but for higher blade tip speed and better distribution of the clippings.
/ Mowing RPM #11
What these fellows said, plus closer to WOT will lead to better battery longevity for some folks, and keep the transmission a bit cooler in my opinion.
Sometimes, in conditions where rabbit speed would be appropriate, I opt for turtle, with WOT, and foot pedal to the floor. I do this because it is not that often I get to put the pedal to the floor, so I wonder about the piston bores in the axial piston pump. Edit...I forget to do this in reverse, so I ought to remember now, since I wrote it, and said it out loud too.*
Tell your kids a good learning technique is to think it, write it, and say it. Do that before bedtime the day before the test.
/ Mowing RPM #12
Good idea. Same pistions used tho, so unless you do a tremendous proportion of backing, just exercising in forward oughta do it. ... Not sure how much issue the different side thrust is.
larry
/ Mowing RPM #13
larry
Larry, in reverse, do you know right off if the pistons stroke a slightly different section of bore? I thought they do but I need to get another cup of coffee and think about it more.
Edit: Coffee was good. Thinking about it, forward swash plate angle is far greater than reverse, so reverse piston travel in reverse is contained as a subset of the forward piston stroke travel. Pressures should be different in reverse in that section of stroke than it would be in forward. It's a minor issue, but interesting.
Anyone not familiar with what goes on in that pump, and if you are willing to sit through a 30 second commercial, you can see PART of the pump internals here:
http://www.metacafe.com/watch/1606910/hydraulic_piston_pump_how_it_works/
Kivel Quick Hitch Skid Steer Attachment (A64553)
Kivel Quick Hitch...
2017 Scag SCZ72V Cheetah 72in. Zero Turn Commercial Mower (A64194)
2017 Scag SCZ72V...
BUSH HOG 1815 - 15' BATWING ROTARY MOWER (A64277)
BUSH HOG 1815 -...
Aluminum Alligator (A65583)
Aluminum Alligator...
FIFTH WHEEL PLATE AND MOUNT (A65643)
FIFTH WHEEL PLATE...
Landhonor FW-13-15000G, Skidsteer Mount Winch  (A62679)
Landhonor...
