MossRoad
Super Moderator
- Joined
- Aug 31, 2001
- Messages
- 67,266
- Location
- South Bend, Indiana (near)
- Tractor
- Power Trac PT425 2001 Model Year
Yes. The mower floats. This is how it works...
The lift arms work exactly like the lift arms on a front end loader. They are permanently attached to the tractor. If you move the joystick forward and backward, the lift arms go up and down. On the end of the lift arms is a male quick attach plate. If you move the joystick left and right, the quick attach plate tips forward and backward, like the dump motion on a loader. ALL attachments have a female quick attach receiver. You drive up to the attachment, use the joystick to slip the male plate into the female receiver, operate a lever under the dashboard to hydraulically close the quick connect lock, pick up the attachment and drive away. The whole process takes about 5 seconds once you get use to it. Just like a front end loader, if you push the joystick past the detent, it goes into float. So a mower will float up and down out in front of the tractor, independent of the tractor. The mower also has a pivot pin that allows for quite a bit of float left and right. And it pivots fore and aft on another set of pins. The mower is able to pitch, roll and elevate independently of the tractor. If you need more traction you can lift the mower a bit to take weight off of it and put the weight on the tractor. This will eliminate the ability for the mower to float until you push the joystick back into float mode. But the other two axis of motion are still there.
