Mowing Ditch Banks
   / Mowing Ditch Banks #21
I'd use Round Up to kill every thing off and then plant some type of grass seed that would be easy to mow with a regular mower. Be careful the wife doesn't see it as an opportunity to make a nice flower garden, if that happens your yard work will more than double ;-)
   / Mowing Ditch Banks #22
You might consider the DR Power 3 point hitch trimmer mower.
I have looked at that several times, and I see they just did a redesign to give it a wider reach, which was one of the showstoppers before. Now it reaches an additional 11" out, so that would be about 33" beyond my rear tires, and it starts to be usable for my needs. I have not seen any reviews on their website of the new redesigned unit -- just mostly negative reviews of the older model. Would be great to see some new reviews before spending $999 on the unit. It sure looks promising.
   / Mowing Ditch Banks #23
I would do the same, but I would plant a ground cover that doesn't require mowing.
Steve
   / Mowing Ditch Banks #25
I used to use a Toro 5 HP walk behind string trimmer for such work. I also have a 60 inch 13 HP Swisher pull behind mower that can be offset approximately 60 inches left or right, although I have never used it in a ditch. Plus it might be to big and heavy for ditch work? but they make smaller ones.
   / Mowing Ditch Banks #26
Back when I used to do hydroseeding and erosion control, I used to run into a lot of ugly ditch situations. Seems everytime some developer would start a new development, they had to fight water run off in one direction or the other. Bare ditches just washed deeper and deeper. Fill the ditch full of riprap and then it would clog up with leaves and other junk that would find its way down the ditch. The best method I found to fix the problem was to slope the ditches where you could run a regular mower up and down the sides. After slopeing, seed the area and apply Turf re-enforcement mats. (TRM's) The grass would grow up thru the mats and the mats prevented the water from washing the ditch out. Because the TRM's made for a smooth surface, the ditches where pretty much self cleaning and any leaves or trash would just flow on down. You might talk to you neighbor and see if they will go along with doing some minor grade work. All it would take is a tractor and scrape to smooth the side of the ditch. I used to use my harley rake and just run down each side letting the rake smooth and level the sides and once done, it was just a matter of spreading seed and rolling out the mat. The mat needs to be stapled to the ground to prevent it from washing out, but once the grass is established, the grass will hold it in place. TRMs really makes maintaining ditch banks as simple as making a pass with the lawn mower.
   / Mowing Ditch Banks #28
   / Mowing Ditch Banks #29
It has seemed promising for a couple years, but reviews here have been lukewarm, and the reviews on the DR site are pretty bad.
The overall "star" ratings don't make it seem too bad, until you look at the individual reviews and notice that some of the worse reviews have 5 stars - looks like the reviewers forgot to set the stars to match their reviews. If they were matching "lukewarm" would be a serious overstatement.
Terry
   / Mowing Ditch Banks #30
A friend of mine may buy one jut because the sickle bar cutters are so expensive. But he hasn't yet. DR has something like a six month return policy.
2024 FORD F250 SUPER DUTY BED (A58018)
2024 FORD F250...
NEW Landhero Mini Skid Steer Loader 23HP (A59000)
NEW Landhero Mini...
Giyi Pallet Forks (A53314)
Giyi Pallet Forks...
WERK-BRAY 23" PIN ON BUCKET (A52706)
WERK-BRAY 23" PIN...
(INOP) 2019 KUBOTA SVL 95-2S SKID STEER (A52707)
(INOP) 2019 KUBOTA...
1980 Gleaner F2 with heads (A56436)
1980 Gleaner F2...
