Mowing Deck question
/ Mowing Deck question #1
ncviauk
Eden
BX 18--
Last year I purchased a BX 1800 with a 54 mowing deck. I can't get the deck adjustable wheels free up they don't stop me from mowing but they will not adjust. I have tried beating them loose but no luck. Any ideas?
/ Mowing Deck question #2
not sure what you mean? the black plastic wheels not turning? or shaft holding the wheels to adjust up and down at preset height?
If you meant thee shaft, its a difficult decision. normally if I didnt have paint to worry about I would add heat from torch on outside collar of shaft till its hot enough to melt candle wax. Let it cool, support bottom of deck and give it a good whack on shaft downwards.
Otherwise, I just might add rust buster fluids you have in your garage. ( wd40 is pretty weak, you need industrail strength. I would mix up ATF and diesel 50/50 and coat the shaft and let it sit overnight before cleaning away with rust breaking fluid and try to free it.
/ Mowing Deck question #3
Mine did that on our BX2200 and I couldn't budge them by banging on them, so after letting them soak in lube, I used a large crescent type wrench and got them to move a bit side to side by twisting and gradually worked them free adding fluid occasionally.
What kind of lube?
What kind of lube?
/ Mowing Deck question #6
Get some PB Blaster. Spray and let it sit overnight. You can get a wrench on the square block where the wheel bolts into the shaft and work it back and forth. If it doesn't free up, spray it again.
/ Mowing Deck question #7
What kind of lube?
To be honest I don't even remember which one as I have different types of lube and penetrating oil in my garage. It will need to be pretty thin to penetrate and as mentioned, it will take time to penetrate.
