mowing at night M7060 lights suck
/ mowing at night M7060 lights suck #1
Little General
Mi. Pleasant , N/C/
Kubota M7060 w cab Kubota x1100c Kubota KX008 John Deere 4400 , JD TLB110
Title says it all. The lights on my M7060 suck and in the time of LED lights, Kubota missed the boat on this one. IU have quite a few LED lights from a buddy of mine that works for Truck Lite that i am going to mount on my tractor. Anyone have any idea what these wires are for?
/ mowing at night M7060 lights suck #2
I have a B3000 with the OEM Kubota Halogen work lights.
I tried cutting grass last week in the dark and it was a real PIA.
It was darker than I thought it would be.
I have just finished installing some Rigid Industries D2 Dually LD's in the back, and looking for some brackets for the front that will work to mount the D2's.
I also have some LED headlight bulbs that I need to try to install.
The rear LED's are a HUGE improvement and I am looking forward to seeing how the front lights look.
/ mowing at night M7060 lights suck #3
Here is the wiring diagram looks a like a plug for another lite, same switch
/ mowing at night M7060 lights suck #4
I have festooned my L3400 with LED lights (basically, cheap ones from China- although they all must come from China these days) since I used to need to snow plow at night occasionally, and they work fine. Two front, two rear, two side, or alley, lights. The current draw is very nominal, and they have worked fine for years. Just warm enough for snow to melt off. Waterproof rocker switches, lighted so if they get turned on in the day, I know it. Also installed a waterproof digital voltmeter, just as a simple way to keep an eye on my battery and charging system. For some reason, I can't remove the photo that shows the earlier version with just the two lights per side...
/ mowing at night M7060 lights suck #5
Like Varmint, I added 6 LED lights, all on my roll cage, and with them all on, I don't even use my factory lights in the grill, they just shine on the back of the loader bucket anyway. I often mow at night, or finish in the dark at least!
/ mowing at night M7060 lights suck #6
Kubota has to have the weakest headlights in the industry. The lights in my M's are comparable to a flashlight with almost dead batteries. I added LED's a long time ago. If good enough for JD, good enough for me.
/ mowing at night M7060 lights suck #7
Here's a description of the current setup on my L4240. Tonight I started mowing after dark because of my schedule the next couple days. The night shot has all the lights turned on, but tonight I turned the two forward facing roof-mounted lights off and still had plenty of light where it was needed. It was also kind of relaxing/cozy without the hood being illuminated. When it's time for snow the grill guard lights won't be much help so I'll be running the cab-mounted lights for sure.
Lighting Revisited - OrangeTractorTalks - Everything Kubota
/ mowing at night M7060 lights suck #8
If those two wires come from up under your rear fender - they are hot leads. They power my rear light. If I had to do night work - I'd be getting LED flood lights from J A McDermott out of Ridgewood, New York. Commercial 12 volt LED flood lights. I've worked on commercial fishing boats that use them.
If you REALLY need lights - these are the ticket.
/ mowing at night M7060 lights suck #9
I have 2x 30W LED flood lights mounted on my ROPS (no, I didn't drill - I simply used wide HVAC band clamps).
I have one mounted for the front, and one reversed for the rear. You can see 500' all around.
/ mowing at night M7060 lights suck #10
While I havnt had to do much night work with my M7060, I have an LED light bar on my car and had some on a truck. Our airplanes at work also have switched to LED landing lights. One thing I don’t like about the LED’s, they make very little heat, and in the winter time ice and slush build up on them and does not melt off like a halogen. In another few months I guess I’ll find out how bad these halogens are for night snow blowing.
/ mowing at night M7060 lights suck #12
Kind of surprised you haven't got a ticket. LED light bars are illegal here in the states for on road use. I'd think Canada is more strict. I hate them anyway. Most idiots aim them way too high and it blinds oncoming drivers....me. If I was a cop I could write a pile of tickets... and I would.
/ mowing at night M7060 lights suck #13
/ mowing at night M7060 lights suck #14
LED light bars are LEGAL in WA state with restrictions. Must be installed on the front of the car and below the level of the hood. Must only come on with high beam - be off with low beam. Off-road - - apparently no restrictions.
/ mowing at night M7060 lights suck #15
FWIW, The F & R cab lights on the new M4 are LEDs.
Probably means that all new models will now have LED lamps.
SDT
/ mowing at night M7060 lights suck #16
SDT
Was at my Kubby dealer yesterday (to pick up some items) and I saw that as well. LED's are much better all around but especially on amperage draw.
/ mowing at night M7060 lights suck #17
Well I can tell you the new 2019 L6060HSTCC tractors do NOT come with LED work lights. I had to wait for mine to ship from Japan and it arrived in July of this year, so I know it is new and it has the crappy halogen lights. My old Massey had better lights. Shame on Kubota.
/ mowing at night M7060 lights suck #18
What I'd really like to find are LED replacement bulbs for the flashlight bulbs in my M9's. I can see better at night with a candle. I've already replace the cab mount lights (halogen) with LED's but I want to get replacement bulbs for the stock in the front grill headlights complete the job. Any ideas?
/ mowing at night M7060 lights suck #19
LEDs & HIDs generally emit light from different locations on the bulb than halogens. So if you put a LED or HID in a halogen housing they don't focus properly. Really bad on a road vehicle blinding oncoming traffic, merely poor lighting on tractors. LEDs put off less heat, but degrade quickly if they actually get warm. You need a lot better heatsinks & cooling than you can get on a halogen housing.
LED fixtures or light bars will work a lot better than a retrofit. My power setup is probably overkill. https://www.tractorbynet.com/forums/customization/376458-let-there-light-l4060-light.html I might have tried it out without the extra wiring if I had it to do over again. Maybe even using a small cube or bar the size of the old halogen housings if you dont want to build the mounts.
My front bar has a leak & fogged. It still works pretty good after I drained it. I'm not expecting it to last to long. When either bar dies I'll likely replace it with a nicer Ridgid or name brand bar.
UNUSED FUTURE 24" HYD TILT MINI EXCAVATOR BUCKET (A60432)
UNUSED FUTURE 24"...
2007 Ford F-150 4x4 Ext. Cab Pickup Truck (A59230)
2007 Ford F-150...
2005 Jeep Patriot SUV (A59231)
2005 Jeep Patriot...
2019 KENWORTH T680 TANDEM AXLE SLEEPER (A59905)
2019 KENWORTH T680...
UNUSED FUTURE FT-GB200-79"X71 1/2"-1" STEEL PLATE (A60432)
UNUSED FUTURE...
2012 VOLVO A40F OFF ROAD DUMP TRUCK (A60429)
2012 VOLVO A40F...
