Mowing acreage.
/ Mowing acreage. #41
Here in North Georgia : you’ll be Invaded with Field Rats IF you let grass grow tall & thick.
Keep it mowed weekly or Bush Hogged monthly & you won’t have a rat problem.
You keep it clear an acre around your place and the birds of prey will feast on the rats. Maybe special for north GA, make it 2 acres.
/ Mowing acreage. #42
Coyote would keep them in check here.
/ Mowing acreage. #43
True but birds & coyotes can’t get to the rats in waist hi grass.
I got badly infested with them here at home eating all the insulation out from under hoods & firewalls of 2 vehicles sitting on the carport.
I remedied that problem buying a 15’ Batwing Bush Hog keeping the hay field cut twice a month
/ Mowing acreage. #44
Your yard must be butter smooth if you can mow 2acres in 30 mins with a 60” ?
i have made it that way with my 4' roller, I can mow at 11mph, full speed. There are 3-4 bumps in the yard but I know exactly where they are. I do the perimeter 2 passes, then up and down in strait shots. It used to take me hours on my cub low boy, this is night and day.
/ Mowing acreage. #45
My farm ground is way too rough & grass too thick to mow fast.
Too hard on eqpt
/ Mowing acreage. #46
for those who complain of rough zero turn ride, ft & rear suspension is the way to go. i can't afford. but my commercial 54" does well on 4 ac plot around 3 ponds
(plus a walk behind zero turn for steep dams)
don't see much mention here of feral hogs. now there's a rough ride, fortunately, not a problem for me, but these hogs aren't going anywhere. i'm sure more manu are making suspension rides, but they're rare even on commercial equip, regards
/ Mowing acreage. #47
I have suspension on my ZT, special ordered to be it had it and it still beats the he!! out of you.
/ Mowing acreage. #48
Wish Google Earth would let you know when they are updating the photos.
/ Mowing acreage. #49
It takes me 9hrs a week to mow.
I mow 3-5hrs at a time weather & farm work permitting.
Kubota ZD1511 72 SD deck 1505cc 4cyl Turbo 30.8hp
& it still bogs pulling my steep hills & banks View attachment 872423
I’ve currently bought a front deck F3710 36.9hp with same 4cyl Turbo engine & 4wd for traction.
Zero with front weights View attachment 872424
Fluid Filled rear tires & 140lbs of brackets & weights up front.
Rides way better, doesn’t rare up & helps with traction on banks
Mine is bumpy as fuaaaaa, and I can do it easy with a 72" Ferris. I have no hills or anything like that to deal with, just some terraces. You can mow, and get a good cut going as fast as the machine will go. Really a time savor.
/ Mowing acreage. #50
Who's mower? I am so impressed with the Ferris I am just floored at how well it does.
This is the video that sold me, yes it has a great deal to do with how the suspension is setup but when it is setup for your weight, it is really this kind of difference.
/ Mowing acreage. #51
I looked at and seriously considered the Ferris and was going to purchase one but because of all the reports I kept finding on-line about having to rebuild the suspension at about 3 years of use so I bought an ExMark Lazer Z with the operator suspension platform.
/ Mowing acreage. #52
I don't mow with my Kubota M6040 for several reasons. It's just too heavy ( 10,000+ ) and with R-1 tires it will rip/tear up the grass and surface - any time of the year. There is no way I could navigate around all my out buildings and house with the M6040.
One thing though - I kind of wish I would have got a mmm with power steering. By the time I have finished mowing it all ( 2 1/2+ acres ) - I'm kind of bushed/shaken, not stirred and covered with grass clippings and pocket gopher mound dust. My mower - JD 570.
Needless to say - my lawns are NOT one big rectangular field.
2016 CATERPILLAR TL1055D TELESCOPIC FORKLIFT (A65053)
2016 CATERPILLAR...
SKID STEER FORK (A64553)
SKID STEER FORK...
2026 Loadtrail 20ft. 7 Ton T/A Deck Over Flatbed Equipment Trailer (A64194)
2026 Loadtrail...
W.R. LONG FAST HITCH FORKS (A64278)
W.R. LONG FAST...
KUBOTA BX1870 TRACTOR (A65054)
KUBOTA BX1870...
SCAN TO RECEIVE TEXT UPDATES (A65053)
SCAN TO RECEIVE...
