Mowing a 14x80 mobile home with a DK55... YES!
   / Mowing a 14x80 mobile home with a DK55... YES! #1
quadmaster50
Bloomington Indiana
Bobcat T770, T650, 435, Case 450C
My neighbor is building a new house and been living in a old trailer and needed it moved, They had a dump truck hooked to it and a 2wd 70HP international on the back pulling and still couldn't move it... Well, I offered to try with my little Kioti and it moved it without even spinning a single tire.... Trailer was still full of all their stuff also....
Im impressed with the little things!!
   / Mowing a 14x80 mobile home with a DK55... YES! #2
I was expecting a photo of a mangled one after backing your brush hog into it.
Bruce
   / Mowing a 14x80 mobile home with a DK55... YES! #3
Bruce
Ha! I was expecting some sort of homemade, 'Redneck Engineered', 3PH, multi-head, weed-whacker set up. :laughing:
   / Mowing a 14x80 mobile home with a DK55... YES! #4
Lol quadmaster50 in some circles the title would be called click bait, I was ready to see you bush hogging a trailer. Never the less nice to see you beat out the international.
   / Mowing a 14x80 mobile home with a DK55... YES! #5
I am currently looking at the NX5510 and noticed (in the shop manual) the towing spec as 9,500 lbs. I'm going to be getting a dump trailer and was going to be using my truck to tow it just in my immediate neighborhood to move a bunch of material. I'm now thinking that if I get the tractor I could just use it: it'll be loading the trailer, as well as spreading the material around.
Yeah, impressive!
   / Mowing a 14x80 mobile home with a DK55... YES! #6
I am currently looking at the NX5510 and noticed (in the shop manual) the towing spec as 9,500 lbs. I'm going to be getting a dump trailer and was going to be using my truck to tow it just in my immediate neighborhood to move a bunch of material. I'm now thinking that if I get the tractor I could just use it: it'll be loading the trailer, as well as spreading the material around. Yeah, impressive!
On flat ground the towing capacity is anything it can move.
   / Mowing a 14x80 mobile home with a DK55... YES! #7
And that would be solid ground!:thumbsup: (I've got flat ground that you can readily get stuck in:eek:)
   / Mowing a 14x80 mobile home with a DK55... YES! #8
The towing capacity is still anything you can move. It's just a lot less.
   / Mowing a 14x80 mobile home with a DK55... YES! #10
Yup. (I've moved massive tree trunks with my dinky B7800- spinning them.)
Just found it interesting that the manufacturer's specs were that high. Towing specs are generally based on the expected operational environments that the equipment will be operated in.
2012 International WorkStar 7500 Vactor 2100 Plus Combination Sewer Jetter Vacuum Truck (A55973)
2012 International...
3 FORKS (A56857)
3 FORKS (A56857)
2007 Capacity TJ6500T Trailer Jockey Truck (A55973)
2007 Capacity...
UNUSED 89" LAND PLANE (A52706)
UNUSED 89" LAND...
2017 Ford F-150 XLT 4x4 Crew Cab Pickup Truck (A55973)
2017 Ford F-150...
2017 Ford F-550 (A55973)
2017 Ford F-550...
