Mowing a 14x80 mobile home with a DK55... YES!
   / Mowing a 14x80 mobile home with a DK55... YES! #1
quadmaster50
Bloomington Indiana
Bobcat T770, T650, 435, Case 450C
My neighbor is building a new house and been living in a old trailer and needed it moved, They had a dump truck hooked to it and a 2wd 70HP international on the back pulling and still couldn't move it... Well, I offered to try with my little Kioti and it moved it without even spinning a single tire.... Trailer was still full of all their stuff also....
Im impressed with the little things!!
   / Mowing a 14x80 mobile home with a DK55... YES! #2
I was expecting a photo of a mangled one after backing your brush hog into it.
Bruce
   / Mowing a 14x80 mobile home with a DK55... YES! #3
Bruce
Ha! I was expecting some sort of homemade, 'Redneck Engineered', 3PH, multi-head, weed-whacker set up. :laughing:
   / Mowing a 14x80 mobile home with a DK55... YES! #4
Lol quadmaster50 in some circles the title would be called click bait, I was ready to see you bush hogging a trailer. Never the less nice to see you beat out the international.
   / Mowing a 14x80 mobile home with a DK55... YES! #5
I am currently looking at the NX5510 and noticed (in the shop manual) the towing spec as 9,500 lbs. I'm going to be getting a dump trailer and was going to be using my truck to tow it just in my immediate neighborhood to move a bunch of material. I'm now thinking that if I get the tractor I could just use it: it'll be loading the trailer, as well as spreading the material around.
Yeah, impressive!
   / Mowing a 14x80 mobile home with a DK55... YES! #6
I am currently looking at the NX5510 and noticed (in the shop manual) the towing spec as 9,500 lbs. I'm going to be getting a dump trailer and was going to be using my truck to tow it just in my immediate neighborhood to move a bunch of material. I'm now thinking that if I get the tractor I could just use it: it'll be loading the trailer, as well as spreading the material around. Yeah, impressive!
On flat ground the towing capacity is anything it can move.
   / Mowing a 14x80 mobile home with a DK55... YES! #7
And that would be solid ground!:thumbsup: (I've got flat ground that you can readily get stuck in:eek:)
   / Mowing a 14x80 mobile home with a DK55... YES! #8
The towing capacity is still anything you can move. It's just a lot less.
   / Mowing a 14x80 mobile home with a DK55... YES! #10
Yup. (I've moved massive tree trunks with my dinky B7800- spinning them.)
Just found it interesting that the manufacturer's specs were that high. Towing specs are generally based on the expected operational environments that the equipment will be operated in.
2 Warehouse Forks (A55787)
2 Warehouse Forks...
FRONTIER 3 PT HAYSPEAR (A57192)
FRONTIER 3 PT...
2019 CATERPILLAR 740GC OFF ROAD DUMP TRUCK (A52707)
2019 CATERPILLAR...
Sakai SV505 (A53317)
JOHN DEERE 323D SKID STEER (A52707)
JOHN DEERE 323D...
2013 F-550 Bucket Truck (A55302)
2013 F-550 Bucket...
