Mower Types
/ Mower Types #21
Bill, although it's obvious now you've mentioned it, I hadn't thought about the mower in the raised position. Thanks for the heads up on those issues. I'll get the final adjustments made in the morning before I lose my 3ph virginity.
/ Mower Types #22
Well, the rfm worked fine in the longer stuff although it needed a few passes. It was fun. I raised the mower a few inches on the 3ph and lowered it each pass. Picked up a few notches in the blades from sticks lying around so need to hit the blades with a file before I put the machine away for the season. Working around the fruit trees was a bit tricky but was still quicker than using the weed eater.
Boy, the Kub. is so much lighter without the backhoe. That was the first time I had it off and the machine felt like it was on steroids!! The next challenge is to reconnect the bh for the first time . . .
213063 (A64276)
213063 (A64276)
2020 Peterbilt 337 S/A Dump Truck (A64556)
2020 Peterbilt 337...
2000 Ford E-350 Shuttle Bus (A64194)
2000 Ford E-350...
Delta BS100 Shopmaster Bandsaw (A64553)
Delta BS100...
T/A CO2 Tanker Trailer (A64194)
T/A CO2 Tanker...
2014 Kobelco SK210LC Hydraulic Excavator (A64553)
2014 Kobelco...
