Rotary Cutter mower rpm question for ford 3400 tractor
   / mower rpm question for ford 3400 tractor #1
Thor22
DeKalb Il
ford 3400
I just bought a ford 3400 tractor 4 speed with loader. I think the rpm is 540. I am going to an auction soon with different used mowers at it, and I was wondering how do I tell which ones are 540 rpm and what size 3pt mower would be best for this tractor?
   / mower rpm question for ford 3400 tractor #2
TractorData.com Ford 3400 industrial tractor information
I think they are all 540 RPM at the PTO. That is just the revolutions per minute the engine puts out at full throttle. Nothing to do with power or the size of the mower it can handle. I would guess your tractor has about 40 horsepower at the power take off. So a 6 foot single spindle mower should work fine. When you get into much higher horsepower you get tractors that are both 540 and 1000 RPM. In the power range you tractor is in all the implements are for a 540 pto......at least that I know of.....
   / mower rpm question for ford 3400 tractor #3
If you look at the tractor end of the pto shaft , 540 rpm will have 6 splines and 1000 Rpm mowers will have I believe 21 splines ( usualy used in higher horsepower mowers. I used to own a ford 3400 and a 6 foot shredder worked fine behind it.
Hope this helps
C-ya
I want to thank everyone for anwsering my questions. They were very helpful.
2008 Sterling Acterra Ambulance (A56858)
2008 Sterling...
(9) ROLLS OF 5' - 10 GAUGE CONCRETE WIRE (A54757)
(9) ROLLS OF 5' -...
Ford 8340 (A53317)
Ford 8340 (A53317)
2021 Caterpillar 308CR Midi Excavator (A55973)
2021 Caterpillar...
2015 Peterbilt 367 T/A Wet Kit Sleeper Cab Truck Tractor (A55973)
2015 Peterbilt 367...
2022 Harley-Davidson FLHTP Police Electra Glide Motorcycle (A55973)
2022...
