Mowing Mower for B3030
/ Mower for B3030 #1
Bob53
SW/PA
B3030
1. If you have a backhoe on a B3030, do you have to remove it to use a mid mount mower?
2. What are advantages /disavantages of mid mount vs one that you pull behnd tractor.
What i would be using mower for is cutting grass , sticker bushes on trails in woods. Plus some field grass. some of the trails are not completly smooth and connot put real low and have to watch for small rocks at times. Some of the sticker bushes we have to get with weed wacker because they hang over the side of trail and too rough, do not think tractor can help there?
Trails are about 12' wide.
Here is some pix of some of what i need to cut, there are rocks here and there one sides at places.
Trail Pix
3. Should i get Kobota or off brand? Do you save that much?
/ Mower for B3030 #2
<font color="blue"> 1. If you have a backhoe on a B3030, do you have to remove it to use a mid mount mower?
</font>
Yes. The 3PH lower links have to be removed to install BH. These are need to raise and lower mower.
<font color="blue"> 2. What are advantages /disavantages of mid mount vs one that you pull behind tractor. </font>
The MMM gives you a good view of what and where mower is cutting.
FEL can be removed when cutting with MMM. This gives better maneuvering in tight spots.
Do not listen to others comments about a MMM being hard to install and remove. The <font color="orange"> Kubota </font> MMM only take minutes to install and remove.
Biggest drawback to the MMM is price. They are about $1000 more than a top quality RFM.
/ Mower for B3030 #3
i don't know about you but I don't think that I would be mowing with a BH on. It wold definately get in the way going around trees and other landscaping items. But since it has to come off anyways it really doesn't matter what type of area your mowing.
/ Mower for B3030 #6
I just purchased a B3030...with the BH, MMM, and FEL. You can run all three at once. True, you must remove the standard 3PT lift arms, but Kubota provides a set of short (about 8") arms...so that you can still raise and lower the MMM and operate the BH. One CAUTION if you also buy the grass catcher: When you do remove the BH, and install the long/standard lift arms...if you also purchase the grass catcher...BE CERTAIN to remove the black grass catcher drawbar support bracket (2 large bolts)...as these bolts interfere with the final few degrees of upward travel of the long lift arms. As I experienced...the grass catcher bolts will damage/bend the **** out of the stabilizer ends, pins and the couplings to the cross shaft. THERE IS NOTHING WARNING ABOUT THIS IN THE KUBOTA MANUALS.
/ Mower for B3030 #7
I see you have a FEL. On my 3130 I raise the front end by curling the bucket of the tractor so you dont have to mess too much with the front wheels obstructing the posts on the front casters.
Since the mower does not have swiveling rear casters, I fashioned a set of swiveling casters using Sch 40 pipe to place the mid rear roller on.
So I lift the front, slide my "dolly" under the rear roller, lower the mower, disconnect the front/rear points, and the pto and roll it out to the side.
/ Mower for B3030 #8
For what you showed in the pictures I would suggest a 3pt finish mower with rear discharge set up. They generally have more hight adjustment plus it would give you a better view of the ground your cutting, you could see a rock or large stump as it passes under the tractor before it gets to the mower
/ Mower for B3030
Thanks for all the responcse a lot good ideas and things i did not think about.
2015 Peterbilt 367 T/A Wet Kit Sleeper Cab Truck Tractor (A56858)
2015 Peterbilt 367...
2005 Nissan Frontier Crew Cab Pickup Truck (A61573)
2005 Nissan...
WHEEL LOADER ARM BRACKET (A64280)
WHEEL LOADER ARM...
2020 International HX620 Quint Dump (A62613)
2020 International...
LOOK! (A63111)
LOOK! (A63111)
CASE TR340B SKID STEER (A64279)
CASE TR340B SKID...
