Mowing Mower deck washer
/ Mower deck washer #11
Finally, I was about to post "what about your bearings" this morning, but ran out of time on the way out. Thank you...
/ Mower deck washer #12
I, too, use the air-compressor on the mower and the string trimmer every time I use them. Of course I also use it on my power saws, drills, and even my electric razor and Wahl hair clippers every time they're used.:laughing:
What the heck do you shave/clip that you need to use an AIR COMPRESSOR to clean your razor off ?!?!
/ Mower deck washer #13
My house is a little different from most.:laughing: I can step out the back door, 12' across the patio/breezeway, into the shop/recreation room, and my air-compressor is right there. So every time I shave, not every day, but most days, I use the air-compressor to blow the whiskers out of the Norelco razor; much, much quicker and easier than using the little brush that came with the razor, taking the heads apart to prevent buildup, etc.
It would be a little different if I had to go outside in the sun or rain or whatever to get to the compressor.:laughing:
/ Mower deck washer #14
Sounds to me that there is no excitement about these deck hose washers. Just a sales gimmick. Although I do have one on my Toro lawn mower and it works good on that. I think it's because of the small 20" deck size. I guess I'm done with using the one on my 54" deck. I just as soon take the deck off and clean it properly.
I also use a leaf blower to completely clean my tractor after mowing.
When I had the walk behind Toro, if it needed more than the air-compressor could do, I had a weight that I occasionally put on the handle to tilt it all the way back with the handle on the ground (actually concrete driveway) and then I used the garden hose and nozzle to clean it. Incidentally, I traded that mower in on my current Toro ZTR. I asked the sales lady about taking a trade, she went and got the owner (her dad), and he came and told me he didn't take trade-ins, but then he went and looked at my walk behind mower and said it was so clean that he could give me a couple of hundred for it.
When I recently bought the [ame=http://www.amazon.com/MoJack-MJEZ-300-Pound-Tractors-Mowers/dp/B00332FB9W/ref=sr_1_1?ie=UTF8&qid=1337774896&sr=8-1]MoJack[/ame], I raised the front of the mower all the way to remove, sharpen, and replace the blade, and then I cleaned the bottom of the deck really good with one of those nozzles that puts out a solid stream of water about the size of a #2 lead pencil.
/ Mower deck washer #15
A leaf blower works for me too, I worry about what the water does to hot bearings.
Yes, I use a leaf blower to blow off the loose grass and debris before hooking up the water. The deck is cool when I wash it. I also keep a grease gun nearby, and give the deck a shot of grease several times a year... no problems so far.
/ Mower deck washer #16
After posting last night I had to cut today and early morning when the grass was still wet because of a Dr. Apt at 1:00pm. It was clumpy and sticking to everything. After I got back at 3, I hooked up the hose and cleaned with deck adapters just to compare with the pressure washing last time cut (Friday-18th:confused2: growing fast). It was almost just as clean except for chute and spindle hubs. I think once it gets dried on for a week then a pressure washer or putty knife is required to open the areas between the three blade circles that are created. I think the bottom side of the deck, the bearings are expected to see damp conditions (chlorophyl/dew?). IMHO it is when a pressure washer is used on the top side of deck that gets bearings (or idlers/pulleys on some) to fail after sitting damp.
/ Mower deck washer #17
I use the built-in deck washer after each mowing and I don't see any grass build-up. The built-in deck washer works well if you use it correctly and shortly after each mowing.
I expect if one were to mow wet grass several times over a period of weeks without cleaning-washing the underside of the deck, the built-in washer would be totally ineffective at removing the grass. With that much built-up and dried grass on the deck underside you'd probably need to scrape and power wash it.
Regarding the shaft bearing damage, I'd think the application of a power washer would do more damage than a little water splashing around under the deck for 2-4 minutes.
Your mileage may vary.... ;)
2001 INTERNATIONAL 4900 WATER TRUCK (A58214)
2001 INTERNATIONAL...
2013 FREIGHTLINER CASCADIA (A60736)
2013 FREIGHTLINER...
Giyi LS43 QA Log Splitter (A60463)
Giyi LS43 QA Log...
2009 Kubota M108S (A60462)
2009 Kubota M108S...
2018 FORD TRANSIT 350 SERVICE VAN (A59823)
2018 FORD TRANSIT...
2021 CAT 304E2 (A53317)
2021 CAT 304E2...
