Mower deck noise
   / Mower deck noise #1
Rubicon1000
Indianapolis
Kubota l2800 4x4 , l3301, bx2670-1, m4900
Hey guys, I've had my bx 2670 for two years and when I first got it the deck wouldn't raise enough to lock it. I read here and ended up adjusting the lift rod on the rear left. Anyway weather the deck is locked up or set for mowing anytime I hit bumps the deck makes kind of a banging noise.
Almost like it's bouncing around but it's worse with the loader on. Is it normal or does anyone else have the same thing? Thanks, Dan
   / Mower deck noise #2
When mines locked in the Top spot, it will bang going over bumps. Sometimes it will help if I try lower the 3pt a little after lifting it up all the way and locking it.
However, mine does not bang when it's in a lower mowing position. Sounds like something's wrong there.
   / Mower deck noise #3
Mine bangs in the top spot too (BX25D) 60 mower. I lower it a tad and it stops.
   / Mower deck noise #4
My BX2200 with the 60" MMM does the same thing raised to the top. Well it did until I solved it. I went to the local hardware store, got a large rubber stopper from the fastener isle, and got some rubber cement and glued it onto where my deck was banging. Solved my deck banging issue for less than 2 bucks.
   / Mower deck noise
Well I finally got the time to check it out, the deck wasn't raising quite enough to hit the stops. Now when it's locked in the up position no more banging. I like the idea about the rubber, if it comes back I'll probably go that route. Thanks, Dan
   / Mower deck noise #6
Does the BX23s have the same MMM as the BX2670...??? My BX23s mower bangs over bumps, and my place is nothing but bumps everywhere. I looked things over, i dont see any type of locking system to lock my deck. I might put some rubber bumpstops in there kind of like Diesel85 did, unless somebody can tell me how to lock the deck in the upper locking range. (???)
New/Unused 78in Quick Attach Rock Bucket (A51573)
New/Unused 78in...
2022 John Deere 8RX 410 Tractor (A53342)
2022 John Deere...
JACTO ARBUS-1000 LOT NUMBER 71 (A53084)
JACTO ARBUS-1000...
1267 (A50490)
1267 (A50490)
2025 New/Unused Wolverine Pallet Fork Frame (A51573)
2025 New/Unused...
2007 Ford Focus Hatchback (A51694)
2007 Ford Focus...
