Mowing Mower deck hydraulic motor.
/ Mower deck hydraulic motor. #1
Mith
Veteran Member
I'm wondering if anyone would be able/willing to read the specs off the motor on their rotary mower, or finishing mower and post them for me.
I'm thinking about building a hydraulic mower deck for my tractor, and I'd like to have an idea of what displacement motors are being used on something that works already. Trying to figure out the necessary torque for a mower is quite tricky.
I have scratch-built a tractor similar to the power-trac, being that it is all hydraulic I dont have a standard PTO, hence the need for a hydraulic run mower.
Thanks.
/ Mower deck hydraulic motor. #2
Mith, there are several different motors on the various PT mowers. Not too long ago I did all the research necessary to replace the deck mounted motor on my PT-425's brush cutter. It wasn't easy, as Power Trac often deliberately obliterates the motor data plate. I'm on the road at the moment, so I don't have access to the motor information, but it is roughly 50cc.
Can you tell us the max flow and pressures of your system? That way the folks with equivalent or close PTs can respond.
Snowridge, I'd appreciate that when you can.
As to flow and pressure, I'll just add another pump so thats pretty flexible.
Looking for maybe 5' width, but I'd also be interested in the motor specs for any of the mowers. As long as I know the machine that the motor is used with I can figure out what I need to know, and just scale it up or down depending on the application.
I'd like to make both a normal mower, and a boom mower would be nice too. So any and all information is appreciated.
/ Mower deck hydraulic motor. #4
OK, I'll dig up the numbers when I get back in a few days. I'm sure others will be posting, too.
/ Mower deck hydraulic motor. #5
OK MITH this is very important.
WE NEED PICTURES OF YOUR MACHINE:D
You can read the story on the build here
It isnt done yet, but it works. I'm still in the playing with the new toy stage, another couple months maybe I'll do the bodywork.
I suppose in terms of operation its very similar to the PT. I've got a 3pt linkage on the back though instead of the PTs loader.
/ Mower deck hydraulic motor. #7
I believe the finish mower decks for the 400 series use a Gresen high speed motor made by Parker; model number MGG20025, diplacement is 0.58 cu in/rev rated at 9.88 horsepower continously, and 12.4 horsepower intermittently. If you search the Power Trac forum, I think you may find it.
Thanks Duane. That motor is much smaller that I was anticipating.
I did a search, but I didnt find anything. I'll give it another shot and see what comes up.
/ Mower deck hydraulic motor. #9
I don't profess to be an expert on this matter but if I were to try to reverse engineer a solution I would start out with the hydraulic power available on various units--which are designed for varying size of mower. The 422/25 series is approximately a 4' mower. The 1430 is approximately a 5' mower. The 1845 runs a 6' mower---etc. You indicated you are thinking of a 5' mower so I would use the hydraulic power for the 1430 and identify a pump that could be installed on your unit that will produce the PTO hydraulic power of the 1430.
Most mowers in this size range use at least 2 blades and 6' mowers typically use 3 blades so direct drive is not a practical option--rather belt drives are used and that introduces the option to run the blades at a speed other than the motor speed. Selection of blade speed is a function of the size of the blade because blade tip speed is the design criteria. Once you know the desired tip speed, the effective gearing between the hydraulic motor and the blade, and the hydraulic flow you can select the displacement of the hydraulic motor. The motor selected will need to be capable of handling the max pressure available.
/ Mower deck hydraulic motor. #10
Good advice, Bob999...
The PT-425's drive a 5' finish mower, BTW, but only a 4' rough-cut mower. The PT-422 has a 4' finish mower available, or you could try the 5' -- but it would likely not perform too well in tall, damp grass.
On those class machines, the 60" finish mower is a 3-spindle, belt-driven design, while the 48" rough-cut mowers have a single stump-jumper spindle, directly connected (my older design has a lovejoy connector though the newer designs are different). Not sure how the 48" finish mower is designed...
Here's a pic of the motor mounting and belt routing on the 60" finish mower:
http://mypowertrac.com/DesktopModul...&ImageID=42&alias=mypowertrac.com&ImageSize=5
/ Mower deck hydraulic motor. #11
How much HP can you dedicate to a hydraulic pump, that's going to be your limiting factor. If say you have 30 HP total, the drive line will use some, Any HP left over with a reasonable speed, can be used to power a hydraulic motor. Plus every thing Bob said. Do you know what kind of blades do you want, a bush hog blade, single shaft, two blade, or a finish mower with three shafts and three blades?
Bob, at the moment I'm really just looking to gain a bit of information rather than copy the PTs system specification.
I might be wrong, but I believe that the PTs only have one PTO circuit that is used for all the attachments, so I would suspect that the flow from that PTO is a compromise to fit as many attachments as possible. I'll be doing the sums as you suggest, probably even working back from the HP requirements for different sized mowers, but knowing the specs of the motors used on the PT attachments gives me a good grounding to work from.
JJ, the machine has 31HP, and it is set up so that the drive is capable of using nearly all of that (I believe about 25HP at full flow and pressure).
However, while using a mower I wont be going at full speed (~10mph) and it wont be running at full pressure so I'll have more HP available for attachments.
I'm thinking about the possibility of getting a larger motor that runs at 540rpm and attahcing that to the back of the tractor and using standard 3ph attachments with a PTO shaft, I can always add a diverter if I want to use that flow for a boom mower or something.
There is alot of possibilities and I havent really decided what I want to do yet.
There is an argument to adding a high flow pump that is capable of using the full 31HP, and sizing the attachments so that there is enough HP left over for drive. If the attachments need more HP I can just slow down on the drive.
That would also allow me to use the full engine HP through the PTO when the machine is stationary.
Thanks guys, its interesting to hear your thoughts on this. I dont have much experience with hydraulic driven mowers so its good to hear from those that have.
/ Mower deck hydraulic motor. #13
The 48 inch finish mower for the PT-425 is also a three spindle design, with the motor driving the center spindle directly. The outer spindles are belt driven off of the center spindle. There is also an adjustable idler pulley.
I think it would be helpful if folks responding to Mith's request would mention the size of their deck along with the motor data.
/ Mower deck hydraulic motor. #14
Mith
I have acquired the hydraulic PTO motor that runs at or near 540., and the bush hog. It was sized for 18 GPM, and 3000 psi. The intent is to power 3pt attachments on the front of a skidsteer. I have every thing necessary to put it all together.
/ Mower deck hydraulic motor. #15
Mith,
FYI, the PT-425 (25HP gas) has an 8gpm at 2500 PSI (max) dedicated PTO pump, an 8 GPM at 2500 PSI (max) pump that powers the steering, lift, curl, and Aux PTO/QA circuits (with priority given to those multiple demands in that sequence), and a 16gpm at 1500 PSI variable displacement pump -- so the sum total output of those 3 pumps can potentially exceed the power available from the engine. All three are direct-connected to the crankshaft -- i.e. spinning at 3600 RPM max.
For example, if you're trying to simultaneously drive, steer, lift, and curl, with the PTO engaged -- everything potentially slows down (most noticeably the steering and lift/curl response) -- it can't produce the max pressures (only the gpm flow) on all three pumps at the same time. I can't tell by the sound if the mower on the dedicated PTO pump slows down, because there's no significant working load (you're not mowing with the deck up in the air only spinning the blades and chopping air)...
Theoretically, both the dedicated PTO pump and the steering/lift/curl/QA pump can produce about 8 HP each at the point of work, given the hydraulic calculators I've seen that factor in efficiency. I haven't done the calculations on the variable displacement drive pump...
Bottom line is that the 25HP machine spins a 60" finish mower (or 48" brush cutter) with about 8 hydraulic HP (max) available at the attachment... that may sound like low HP to those used to ag/CUT/SCUT tractors, but I'd remind them that my 12 HP Simplicity drives a 48" belly mower, giving arguably the best cut in the business (for a tractor), while hauling my butt around...
The design of the deck itself is also important -- the PT finish mower deck would handle tall thick (or wet) grass much better if it were a deeper deck with more room for the clippings to churn around underneath the deck, without having to chop them over and over...
/ Mower deck hydraulic motor. #16
Mith,
PTs have one PTO and you may well be correct about compromise but I think that mowing is likely the design point for the following reasons:
1. The 1845 is primarily a mower. While it is true that other attachments can be used the design appears to be optimized for mowing steep slopes.
2. For the other units, if you look at the hydraulic attachments available none of them require much power for movement when being used, with the possible exception of the powered rake. Conversily mowing, particularly on slopes which is a forte of the PT design, requires substantial power to move the tractor/mower/operator around and the selection of the amount of power to allocate to the PTO must take that into account to get a machine with satisfactory performance.
/ Mower deck hydraulic motor. #18
At 18 GPM PTO, a 540 rpm hydraulic motor with a torque of 3,678 in lbs to drive 3pt implement, would need to be 7.7 cu in displacement , and pumping 18 GPM at 3000, would take 37 HP. The efficiency of hydraulic pump to motor is 85 %. This is assuming that hoses are short and sized correctly and QD's if used are sized one sized larger. If you want to know exactly what you have when finished, put a pressure gage and a flow meter in the line and you will know.
/ Mower deck hydraulic motor. #19
Mith,
The PT425 has one MAIN pto with 8GPM@2500PSI and one AUX pto. The aux is what powers the cylinder for the quick attach, steering and lift arms, as well as the angle on the plow, the grapple, etc...
/ Mower deck hydraulic motor. #20
Mith, the deck mounted hydraulic motor that came on my 48" brush cutter was a re-branded M+S Hydraulic MLHR 50 wheel motor. M+S Hydraulic is a Bulgarian company. The motor seized, and I replaced it with a Parker TJ0050US080AAAA wheel motor, which has roughly the same specs. The Parker was built to order for me. Nobody had them in stock.
I strongly suggest you do not directly deck mount the motor, as Power Trac is now doing with the 48" brush cutter. In my opinion, the shock loading is what caused my motor to fail very early in life. The older models have a different motor mounted on a bracket. The motor is coupled to a blade hub by a Lovejoy coupler. It provides at least some isolation from shock loads. The variant I have has none.
It is easy to find straight shaft motors of the right size for the old style brush cutters. It is very difficult to find tapered shaft wheel motors for the current models, other than the M+S model that failed, which is quite expensive. The Parker was much cheaper, but must be built to order, and most US suppliers don't catalog it.
I did not want to go with a larger displacement wheel motor, which are much more readily available, as it would have produced unacceptably slow blade speeds.
2010 Honda Civic Sedan (A66738)
2010 Honda Civic...
Rotary Auger Motor Attachment (A61572)
Rotary Auger Motor...
2014 MAC FLAMELESS HEATER TRAILER (INOPERABLE) (A67714)
2014 MAC FLAMELESS...
2021 Ford Explorer AWD SUV (A66738)
2021 Ford Explorer...
2012 INTERSTATE TRAILER 28 T/A GOOSENECK TRAILER (A67714)
2012 INTERSTATE...
No compression. Unknown operating condition. (A64553)
No compression...
