Mower Deck Coatings
   / Mower Deck Coatings #1
FED2782
Anyone have a solution for keeping the mower deck free of grass buildup?
   / Mower Deck Coatings #2
I tried a graphite paint. It did not help much.
Tim
   / Mower Deck Coatings #3
:eek:
So many solutions... ;)
1. Denial - Let the grass grow. I don't care if it gets long. Besides, it combats global warming by sucking down some carbon.
2. Avoidance - No time to mow the lawn anyway, since I have so any other things to do. One of those things is making up lists to post on the internet.
3. Tom Sawyer - Convince your friend that they want to mow your lawn, using their own mower.
4. Scorched Earth - Use liberal doses of a good defoliant. Follow up with green painted gravel.
5. Scorched Earth 2 - Hope that global warming turns your yard into desert.
6. Political - Apply teflon paint to your deck.
Since Google tells me there are indeed Teflon paints to be found, maybe that is a viable solution.
John
   / Mower Deck Coatings #4
Only mow when the grass is dry.
   / Mower Deck Coatings #5
   / Mower Deck Coatings #6
I've used paste wax on a clean deck with some success.
   / Mower Deck Coatings #7
I used slip plate sold by John Deere. It works for a while.
Best advice: Only mow when dry. Stay away from mulching decks/kits. Pressure wash occasionally.
   / Mower Deck Coatings #9
Coat the bottom of the deck with oil, we use old motor oil. Then at the end of the day all that grass scrapes right off and the oil protects the deck from rust...it's a trick my wifes granpappy used in the cemetery back in the day.
It works on mulching decks as well. Some of us don't have the luxury of waiting until the grass is dry to mow. When the cemetery needs mown, we gotta mow it, dry or not. We switched to mulching decks and it keeps wet grass from blowing on the headstones which is nice.
Try the oil, it works.
23018 (A53424)
23018 (A53424)
Ford 655C 2WD Cab Backhoe (A55218)
Ford 655C 2WD Cab...
Greenworks Commercial 82V CZ60R Zero-Turn Mower- BRAND NEW, NEVER USED (A55218)
Greenworks...
2003 GMC C7500 16ft Cab and Chassis Truck (A51692)
2003 GMC C7500...
2014 Infiniti QX60 SUV (A53424)
2014 Infiniti QX60...
2020  FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A52576)
2020 FREIGHTLINER...
