Mower conditioner ... Impeller or roller??
/ Mower conditioner ... Impeller or roller?? #1
blueriver
Super Member
S.E.Oklahoma
JD 5520 Montana 4340 Farmall Super A Montana 5720C
I'm going to plant 30 acres of Pearl Millet ... it will require a mower conditioner. I have yet to own one therefore you guys with experience talk to me.
From my understanding there are two types. The Impeller which is a disc mower and the conditioner is like a flail mower. The Roller also a disc mower with rubber rollers as the conditioner. Pearl Millet is a fast growing tall grass that you cut at 36-42" tall with a stalk about the size of a pencil and will need conditioning. One guy I talked to says to use a batwing mower and chop it up ... don't know about that.
My local dealer has 2 used one's about the same condition, the Impeller is $3500 and the roller type is $6500 ... which way to go is the question.
/ Mower conditioner ... Impeller or roller?? #2
The key descriptive word in your question is grass. That makes my preference flail conditioning. If your primary crop is a legume, the debate gets more spirited.
Okay ... grass. A flail type would be suitable for Millet, bermuda, bahia, prarrie and native grasses.
/ Mower conditioner ... Impeller or roller?? #4
if it was me id get the 1 with rubber rollers.the steel rollers shatter the stems.an you just want them cracked so they dry quicker.
Very good point ... are the rollers worth 3K more?
/ Mower conditioner ... Impeller or roller?? #6
Flail conditioner and steel roller conditioner are two completely different systems. Flail conditioner systems were developed in Europe where grasses are the predominant hay crop. Flail conditioned grass crops will dry quicker than roll conditioned grass crops. Properly adjusted, flails will rub the waxy coating from grass stems & leaves, allowing moisture to evaporate. The technology is proven and effective, and your crop is right for that system.
Given two machines in similar mechanical condition, spending an additional $3000 for roll conditioning would be a waste of money and probably a functionally inferior choice to boot.
/ Mower conditioner ... Impeller or roller?? #7
well let me put it to you this way if i was buying a discbine mower/co id buy the 1 with the rubber rollers.we used to cut millet an haygrazer with an mow/co with rubber rollers.
/ Mower conditioner ... Impeller or roller?? #8
And if I had never used anything else, I'd probably feel the same.
/ Mower conditioner ... Impeller or roller?? #9
i looked at 2 new discbines last year 1 with steel rollers an 1 with the rubber rollers.an i didnt like the steel rollers at all.an my buddy was the 1 thinking about the discbine.an he knew we had run mow/co before going to disc mower.so if i was me id buy the rubber roller rig.
/ Mower conditioner ... Impeller or roller?? #10
Just for grass hay a drum mower with flail conditioner is my favourite . It will dry faster than any type of roller .
I like sickle haybines with rubber for alfalfa .
2013 Ford F-350 4x4 Crew Cab Knapheide Service Truck (A61573)
2013 Ford F-350...
2022 Mack Anthem T/A Wet Kit Day Cab Truck Tractor (A61568)
2022 Mack Anthem...
2018 Volvo VNL T/A Sleeper Cab Truck Tractor (A61573)
2018 Volvo VNL T/A...
7102 (A61567)
7102 (A61567)
6 Row Harrell Stalk Chopper (A62177)
6 Row Harrell...
KMC 3386 (A64119)
KMC 3386 (A64119)
