Mower blades
/ Mower blades #1
m5040
CT
Kubota M6040 L2250, JohnDeere 310D, Ford 841 Elenco, Ford 961, Trapmaster, PT180 w/LM bucket and 45" brush cutter, PT1430 Deutz w/grapple bucket, Antonio Carraro Tigrecar 6500. John Deere 5300. Former owned Steiner 430 max, Goldoni REV Maxter 7
Went to check the torque of the blade mounting bolts, but I don't remember installing shredder blades on my 180 mower.
/ Mower blades #2
Might be me... Your images don't show up just says 'attached thumbnails'.
/ Mower blades #5
Looks like someone put a bead of weld on the edge...
I'd say you got your money out of them.👍
/ Mower blades
No welds, that is how they chip away when rocks are hit. They still do a good job on grass, tall and otherwise. Some other brands seem to be softer and kind of mushroom when impacting rocks.
/ Mower blades #7
Y’all didn’t know that serrated blades are a new trend? M5040 has fully committed to this new fad!
/ Mower blades #8
Interesting wear. I just replaced mine, no rust some obvious "hard object" impacts. They tapered from thin on the outside, to thicker toward the center. Probably lost 25% maybe a little more of material. I should add, the wear was relatively smooth and not pitted like the pict.
/ Mower blades
The rust is because it is the first time I used it this year, (took the pic before use). Where I cut with it, I wait until it is 1 or 2 ft high. The chips are caused by hitting numerous rocks hidden in the weeds. As bad as it looks, it is holding up surprisingly well.
/ Mower blades #10
Yes, i don't have many rocks, just where the driveway is. As a matter of fact, when i first came out to this property, there was a primitive path i was walking down, I needed something like a rock to bash something, i don't remember what, and i looked around and around and couldn't find one flipping rock.
/ Mower blades #12
Rocks are just like the police, when ya need one they can't be found, but mow a new piece of ground and they're everywhere.
/ Mower blades
HAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA!!!!!
Never heard of salting a lawn, I would have thought it would kill everything. It sure does with metal.
/ Mower blades
Opps, I better get back outside and wash my lawn
/ Mower blades
I am trying, but they grow faster then the grass.
/ Mower blades #19
Rocks in the background, rocks in the foreground and rocks in the bucket. You don't need a mower, you need a chisel.
RIDGID AIR COMPRESSOR (A67714)
RIDGID AIR...
KUBOTA B2601 TRACTOR (A65057)
KUBOTA B2601...
2018 International DuraStar 4300 26ft. Box Truck (A61573)
2018 International...
PORTA POTTY (A67714)
JOHN DEERE 5100 TRACTOR (A63291)
JOHN DEERE 5100...
2018 MACK LR633 6X4 T/A SIDE LOAD GARBAGE TRUCK (A66091)
2018 MACK LR633...
