Mower blades
/ Mower blades #1
m5040
CT
Kubota M6040 L2250, JohnDeere 310D, Ford 841 Elenco, Ford 961, Trapmaster, PT180 w/LM bucket and 45" brush cutter, PT1430 Deutz w/grapple bucket, Antonio Carraro Tigrecar 6500. John Deere 5300. Former owned Steiner 430 max, Goldoni REV Maxter 7
Went to check the torque of the blade mounting bolts, but I don't remember installing shredder blades on my 180 mower.
/ Mower blades #2
Might be me... Your images don't show up just says 'attached thumbnails'.
/ Mower blades #5
Looks like someone put a bead of weld on the edge...
I'd say you got your money out of them.👍
/ Mower blades
No welds, that is how they chip away when rocks are hit. They still do a good job on grass, tall and otherwise. Some other brands seem to be softer and kind of mushroom when impacting rocks.
/ Mower blades #7
Y’all didn’t know that serrated blades are a new trend? M5040 has fully committed to this new fad!
/ Mower blades #8
Interesting wear. I just replaced mine, no rust some obvious "hard object" impacts. They tapered from thin on the outside, to thicker toward the center. Probably lost 25% maybe a little more of material. I should add, the wear was relatively smooth and not pitted like the pict.
/ Mower blades
The rust is because it is the first time I used it this year, (took the pic before use). Where I cut with it, I wait until it is 1 or 2 ft high. The chips are caused by hitting numerous rocks hidden in the weeds. As bad as it looks, it is holding up surprisingly well.
/ Mower blades #10
Yes, i don't have many rocks, just where the driveway is. As a matter of fact, when i first came out to this property, there was a primitive path i was walking down, I needed something like a rock to bash something, i don't remember what, and i looked around and around and couldn't find one flipping rock.
/ Mower blades #12
Rocks are just like the police, when ya need one they can't be found, but mow a new piece of ground and they're everywhere.
/ Mower blades
HAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA!!!!!
Never heard of salting a lawn, I would have thought it would kill everything. It sure does with metal.
/ Mower blades
Opps, I better get back outside and wash my lawn
/ Mower blades
I am trying, but they grow faster then the grass.
/ Mower blades #19
Rocks in the background, rocks in the foreground and rocks in the bucket. You don't need a mower, you need a chisel.
2013 Ford F-150 4x4 Ext. Cab Pickup Truck (A66736)
2013 Ford F-150...
(INOP) 2013 MACK ELITE LEU633 GARBAGE TRUCK (A65057)
(INOP) 2013 MACK...
2011 Cub Cadet 42in Riding Lawn Mower (A66738)
2011 Cub Cadet...
PALLET OF 2 SHOP VACS AND SHOP BROOMS (A67714)
PALLET OF 2 SHOP...
2023 Wallenstein BXTR6438 Towable Woodchipper (A66734)
2023 Wallenstein...
2027 . . (A67714)
2027 . . (A67714)
