Grading mower blade clutch
/ mower blade clutch #1
dqkid66
Hey Great Site.
bought a 139 hour CC hds2135 last spring. only problem i have had is sometimes blade clutch wont work when i pull switch. 2 or 3 times during summer it happened when i got off mower for a break but i let mower set about 30 mins and it worked. weather is cool now and it wont work at all. all the times before it worked on initial use of the day. thanks for your help in which way to proceed. parts or repair shop??.
i do all my regular auto repair so if a part will fix it i am comfortable doing work myself
/ mower blade clutch #2
I assume that you have an electric PTO clutch. Usually when they operate intermittently like yours, it's due to excessive gap between the clutch plate and hub. There are probably three adjustment bolts where you can decrease the gap. I don't have a service manual handy but I think the gap should be around .020 inches. Check it in three places around the clutch to make sure it is adjusted evenly.
thanks i will get on that project in the morning, tommy
78in. Skid Steer Bucket (A65640)
78in. Skid Steer...
INSPECTION (A65583)
INSPECTION (A65583)
Newton Crouch PT Stainless Steel Spreader (A64126)
Newton Crouch PT...
(1) 40 Yard Roll Off Dumpster and (1) 30 Yard Roll Off Dumpster (A65579)
(1) 40 Yard Roll...
1998 International 4700 Flatbed Dump (A62613)
1998 International...
New/Unused Landhonor Quick Attach Pallet Forks (A65583)
New/Unused...
