Moving stuff with a BX24's backhoe.
   / Moving stuff with a BX24's backhoe. #11
The suggestion of an ATV and dump trailer is good. If you are digging on a lawn I wouldn't want to use any kind of skid container on it. Rubber tired ATV trailers are pretty cheap. I bought one years ago at Walmart for about $80. It has a removable end gate and is a manual dump. It holds about half a yard. If you were doing these projects daily it might seem very impractical to only haul half a yard at a time but if these projects are infrequent this solution makes sense. You don't have to drag a skid along the lawn and don't have to drive a pick-up on the lawn or turn a tractor around on it to use the FEL.
I use my tractor for the big jobs (like digging a trench) but use my ATV for all the other jobs it is better at.
Tom
   / Moving stuff with a BX24's backhoe. #12
I have a 15cf dump cart I tow behind our old Toro, I pull that along side where I am digging and fill the trialer with spoil. Otherwise for mulch I'll fill the trailer by itself then connect it to the back of the BX and take it where I need it.
   / Moving stuff with a BX24's backhoe. #13
Has anyone ever put a trailer ball on the back end of the backhoe? Seems to me that would make it easy to fill then carry a small trailer with minimal disruption to the lawn etc.
   / Moving stuff with a BX24's backhoe. #14
RedDirt said:
Got a picture of your homemade dump trailer?
HERES ONE with daughter playing truck driver:)
   / Moving stuff with a BX24's backhoe. #15
YES.Its a junk of i beam with a hole in it so i can use my diffferent balls that go with my reese hitch.Grab it with my thumb and go,works great.SIMPLE TO MAKE.
ALAN
   / Moving stuff with a BX24's backhoe. #16
Alan,
That is a GREAT idea. I was considering welding a reese receiver on the back of the bucket, but this is a much better idea.
Thanks
   / Moving stuff with a BX24's backhoe. #17
Mike_V said:
I want to dig up dirt with the backhoe and move it to another location.
There are some situations where that method is not desirable. One, for example, is when you are digging on a lawn and you don't what to have to scrape the soil out of the grass with the FEL. Another is when you are depositing the dirt on a slope or a bank of a pond and there is no real good way to pick it up with the FEL.
*So, I was wondering if it would be practical to dump the dirt into a receptical of some kind (like a 55 gal drum, for example) that would have chains that you could lift with the backhoe teeth and carry away.
*How about this?
   / Moving stuff with a BX24's backhoe. #19
Here's a dump trailer that might interest you:1600 Utility ATV Wagon - Power Dump Cart, dumping ATV Trailer- Power RAM strongest, best, ultimate atv farm trailer, atv ranch trailer
Another (cheaper) possibility is to use what is known as a "stone sled" or "rock sled". If you do a search for these terms in the archives, you will find several threads. Many people just go to an auto salvage yard and find an engine compartment hood that has a shape like a snow sled. The "sled" is just dragged from place to place to move big rocks. The same thing might work to move soil. Depending on your circumstances, some welding modifications for reinforcement or to retain the soil might be worth considering.
2016 WITZCO RG-35 RGN LOWBOY TRAILER (A50459)
2016 WITZCO RG-35...
2014 Gillig G27B102N4 31+56 Low Floor Passenger Bus (A50323)
2014 Gillig...
2018 John Deere 1445 72in Front Mower (A48082)
2018 John Deere...
2017 Buick Encore SUV (A50324)
2017 Buick Encore...
2016 Takeuchi TL8 (A47384)
2016 Takeuchi TL8...
2020 Ford F-150 Crew Cab Pickup Truck (A50323)
2020 Ford F-150...
