Moving round bales with the BX2370
   / Moving round bales with the BX2370 #1
bunyip
Elite Member
Flynn Victoria Australia
Kioti DK 5810 HST
It can be done!!
With the forks on the bucket I can get under the bale and tilt back slightly, the forks then act like a sled across the paddocks, 4WD is a must as the back wheels come up sometimes but overall low and slow gets us there without incident, apart from being harassed by hungry horses.
   / Moving round bales with the BX2370 #2
Is that the smallest tractor made along with the tiniest round bale ever baled?
When my tractor isn't running, I buy a round bale from the feed store and they load it into the back of my truck, then I roll it out of my truck into the pasture.
The 18 is smaller, we have a hay shed full of round bales about 4' instead of the standard 5', stacked 3 high we push them of, tip them over with the forks then slide them out, they weigh about 300kg plus the 4 in 1 bucket and the forks, it doesn't struggle and is the only way I can get them out rather than rolling them, we take the wraqp off when it arrives and put a feed net over them so the horses don't destroy and scatter it everywhere.
   / Moving round bales with the BX2370 #4
And if you had forks directly attached to the FEL instead of hanging off your bucket, you would have a heck lot more of lift!
   / Moving round bales with the BX2370 #5
True.
And I'd lower the counterweight on the 3PH to mid so that it hangs out a wee bit more.
I use the forks to move pallets around with bits and pieces as well as 1000 litre water tanks (empty), they cost about $200, I cannot justify a set of dedicated forks.
We have just sold our property and will be buying a bigger tractor when we move but that is another can of worms as I have no idea what to get as yet but it will need to be able to lift round bales, full size to store them when we cut hay.
   / Moving round bales with the BX2370 #7
Great news on the property sale! :thumbsup:
You're probably looking at a high 30 to low 40hp tractor to handle full rounds. Mine is a 41hp and I've no problem with a 6x5 round (slowly). Mind you, I can only stack two high due to the reach of my FEL.
   / Moving round bales with the BX2370 #8
Kind of wonder about front axle stresses from overloading like that
   / Moving round bales with the BX2370 #9
Having ""adequate counterweight on 3 pt hitch"" greatly reduces stress & wear on frt axle when handling heavy loads with frt end loader.
LandHonor PTO Skid Steer Attachment (A56857)
LandHonor PTO Skid...
1605 (A57192)
1605 (A57192)
2017 Takeuchi TL12R2 Skid Steer, S/N 412100259, Kubota Diesel Engine, Joy Stick Operating Controls, (A59076)
2017 Takeuchi...
2016 Dodge Ram 5500 4x4 Crew Cab Stellar 4421 4,000lb 2 Ton Crane Service Truck (A55973)
2016 Dodge Ram...
2011 Ford F-150 Crew Cab Pickup Truck (A56858)
2011 Ford F-150...
2020 DRAGON ESP...
