Moving round bales with the BX2370
   / Moving round bales with the BX2370 #1
bunyip
Elite Member
Flynn Victoria Australia
Kioti DK 5810 HST
It can be done!!
With the forks on the bucket I can get under the bale and tilt back slightly, the forks then act like a sled across the paddocks, 4WD is a must as the back wheels come up sometimes but overall low and slow gets us there without incident, apart from being harassed by hungry horses.
   / Moving round bales with the BX2370 #2
Is that the smallest tractor made along with the tiniest round bale ever baled?
When my tractor isn't running, I buy a round bale from the feed store and they load it into the back of my truck, then I roll it out of my truck into the pasture.
The 18 is smaller, we have a hay shed full of round bales about 4' instead of the standard 5', stacked 3 high we push them of, tip them over with the forks then slide them out, they weigh about 300kg plus the 4 in 1 bucket and the forks, it doesn't struggle and is the only way I can get them out rather than rolling them, we take the wraqp off when it arrives and put a feed net over them so the horses don't destroy and scatter it everywhere.
   / Moving round bales with the BX2370 #4
And if you had forks directly attached to the FEL instead of hanging off your bucket, you would have a heck lot more of lift!
   / Moving round bales with the BX2370 #5
True.
And I'd lower the counterweight on the 3PH to mid so that it hangs out a wee bit more.
I use the forks to move pallets around with bits and pieces as well as 1000 litre water tanks (empty), they cost about $200, I cannot justify a set of dedicated forks.
We have just sold our property and will be buying a bigger tractor when we move but that is another can of worms as I have no idea what to get as yet but it will need to be able to lift round bales, full size to store them when we cut hay.
   / Moving round bales with the BX2370 #7
Great news on the property sale! :thumbsup:
You're probably looking at a high 30 to low 40hp tractor to handle full rounds. Mine is a 41hp and I've no problem with a 6x5 round (slowly). Mind you, I can only stack two high due to the reach of my FEL.
   / Moving round bales with the BX2370 #8
Kind of wonder about front axle stresses from overloading like that
   / Moving round bales with the BX2370 #9
Having ""adequate counterweight on 3 pt hitch"" greatly reduces stress & wear on frt axle when handling heavy loads with frt end loader.
2020 MACK PINNACLE (A58214)
2020 MACK PINNACLE...
2007 KENWORTH T800 BOBTAIL KILL TRUCK (A58214)
2007 KENWORTH T800...
2007 STERLING LT9500 MIXER TRUCK (A58214)
2007 STERLING...
2020 VOLVO 760 TANDEM AXLE SLEEPER (A57880)
2020 VOLVO 760...
2012 TOP HAT TRAILER GOOSENECK FLATBED TRAILER (A58214)
2012 TOP HAT...
Genie GTH 844 Telescopic Forklift (A57148)
Genie GTH 844...
