Moving Round Bales of Hay
   / Moving Round Bales of Hay #1
RS69
Ohio
Yanmar
Greetings,
I have a 1610D with a Bushhog FEL, I wanted to see what folks are doing to move their round bales of hay? I built a quick attachment for the bucket, so I can remove it and was thinking of using a pallet forks. However, after reviewing the weight of the bales 800 to 1300 pounds, this might be too much for it.
So option #2 is a bale spike/forks attachment on the 3 point hitch. Is there one already made that folks are using? I see some on Amazon, but they state they are for a CAT 1 3 point. However, I know that some CAT 1 implements are not a direct fit for some of our Yanmars.
Thanks,
Rick
   / Moving Round Bales of Hay #2
You are going to need a much bigger tractor to lift an 800 lb. hay bale.
I have a bigger/older tractor, however, the Yanmar is my utility tractor. The other tractor is a AC D12(no FEL on it). This is my parade tractor and thinking about the 3 pt hitch bale spike option on it if the Yanmar cant support. I have seen a youtube video that someone was using a Ford 1900, and I was thinking this was about the same size/capacity of the 1610d which they used a spike on the 3 pt hitch.
   / Moving Round Bales of Hay #4
The Ford 1900 is a lot more tractor, 11 more hp and 1000+ lb. heavier.
Ok, thanks for the follow up. I will look into options for the AC tractor.
   / Moving Round Bales of Hay #6
Pallet forks on a 3 point need a hydraulic toplink to be effective moving round bales.
Here is what I have, it fits SSQA and the 3 point: SpeeCo Products
I had to add a longer top spear to handle 5x6 bales:
Rock Bucket (A50121)
Electric Mobility Scooter (A51694)
Electric Mobility...
2004 IH 5600l Snow Plow Truck (A52384)
2004 IH 5600l Snow...
Zimmerman 6 Lug Running Gear (A50774)
Zimmerman 6 Lug...
KJ Double Ply Polyester Webbing Sling (A50121)
KJ Double Ply...
