Moving Round Bales of Hay
   / Moving Round Bales of Hay #1
RS69
Ohio
Yanmar
Greetings,
I have a 1610D with a Bushhog FEL, I wanted to see what folks are doing to move their round bales of hay? I built a quick attachment for the bucket, so I can remove it and was thinking of using a pallet forks. However, after reviewing the weight of the bales 800 to 1300 pounds, this might be too much for it.
So option #2 is a bale spike/forks attachment on the 3 point hitch. Is there one already made that folks are using? I see some on Amazon, but they state they are for a CAT 1 3 point. However, I know that some CAT 1 implements are not a direct fit for some of our Yanmars.
Thanks,
Rick
   / Moving Round Bales of Hay #2
You are going to need a much bigger tractor to lift an 800 lb. hay bale.
I have a bigger/older tractor, however, the Yanmar is my utility tractor. The other tractor is a AC D12(no FEL on it). This is my parade tractor and thinking about the 3 pt hitch bale spike option on it if the Yanmar cant support. I have seen a youtube video that someone was using a Ford 1900, and I was thinking this was about the same size/capacity of the 1610d which they used a spike on the 3 pt hitch.
   / Moving Round Bales of Hay #4
The Ford 1900 is a lot more tractor, 11 more hp and 1000+ lb. heavier.
Ok, thanks for the follow up. I will look into options for the AC tractor.
   / Moving Round Bales of Hay #6
Pallet forks on a 3 point need a hydraulic toplink to be effective moving round bales.
Here is what I have, it fits SSQA and the 3 point: SpeeCo Products
I had to add a longer top spear to handle 5x6 bales:
2025 Auto Darkening Welding Helmet (A50322)
2025 Auto...
TRUCKING INFO (A50774)
KJ 7'x20' Metal Gate (Deer) (A50121)
KJ 7'x20' Metal...
2009 JLG 1930ES ELECTRIC SCISSOR LIFT (A51242)
2009 JLG 1930ES...
General 7000 EXL 7000 Watt Generator (A50322)
General 7000 EXL...
2017 Peterbilt 567 Day Cab (A52384)
2017 Peterbilt 567...
