Rotary Cutter Moving on up - My Rotary Cutter decision dilema
   / Moving on up - My Rotary Cutter decision dilema
Thanks. I am confident I will be happy. It would have to be pretty bad for me to really regret it. I don't envision that.
   / Moving on up - My Rotary Cutter decision dilema #22
Congratulations!!
David from jax
   / Moving on up - My Rotary Cutter decision dilema #23
Glad you made a decision you’ll be happy with. We all make decisions based on dealer support and cost. But in the end the work gets done. That’s what matters.
Thanks guys. It seems there isn't a lot of (good) video's out there on this cutter with this size tractor. I plan to do a fairly in depth video once I get it and will post it up. I have a drone, etc so I should be able to get some decent video of it in action (I hope).
   / Moving on up - My Rotary Cutter decision dilema #25
I like your choice!
   / Moving on up - My Rotary Cutter decision dilema #26
Good luck with the purchase, definitely keep us informed on how you like it. I’m looking at them too and the rhino and landpride are my two choices. I’m working on getting one to try out just to see how I like it.
   / Moving on up - My Rotary Cutter decision dilema #27
Definitely looking forward to seeing it in action
   / Moving on up - My Rotary Cutter decision dilema #28
Good choice. You will love the batwing. I've had many cutters in my life, finish mowers, good rotary cutters, multi-spindles, ultra heavy duty (which I still have). But the Batwing, that thing just makes me smile when I hook it up. It mows so nicely, it follows the land better than my zero turn, it does a fantastic job, it's easy to use/hook up, I don't have to run at 10MPH to make progress. I love it, it's perhaps the best implement purchase I've ever made (and also, the most expensive). Honestly, the only downside? Zerks. So many zerks. Greasing the thing is an hour job, there are just so many moving points that need it it's ridiculous. But I'm also ridiculous with maintaining gear, so.. There's that.
I'd buy another one tomorrow if it was stolen, no doubt. I have the Woods BW12 and a Kioti 60HP to swing it, using it mostly to clip pastures, but I've never felt "low on HP" in any normal situation. No, it's not gonna mow flat out in 4ft high grass, but I never do/need that. It'll mow as fast as I care to go over my uneven ground and do a fantastic job doing it. It cuts the mowing time a little more then 1/2 from my old 6ft, and it does a much, much better job. You made the right decision, just get a powered grease gun to go with it, you'll want it quickly when you realize the ridiculous number of points that call for regular greasing! ;)
Short update for those interested. I finally was able to get some video today of using the cutter. I literally parked it until we started mowing today and shooting video so this is literally its first use. This is just some uncut drone video I will be using to make a full review later, but shows the unit in action on my MX5800. Tractor ran it great. Was mowing a little low in this video so we added one more spacer when I stopped at the end and it made a big difference in how well it dispersed the clippings. The field doesn't look too long, but it is pretty thick. Very happy with how it peformed. I will put up a complete review in the next couple of weeks.
For reference the already cut strip was two passes from my 6' cutter I used a couple of weeks ago. I think this mower actually gets me more cut than two passes of the other due to overlap.
RC2512 Drone Video 2 - YouTube
   / Moving on up - My Rotary Cutter decision dilema #30
Looks like it’s going to work great for you, thanks for the update. Also keep us informed of any issues or how it’s working out after you get a lot of seat time.
2016 Morbark Chipper (A55787)
2016 Morbark...
ELECTRIC GOLF CART (A58214)
ELECTRIC GOLF CART...
2007 LUFKIN END DUMP (A58214)
2007 LUFKIN END...
2021 Deere 331G (A53317)
2021 Deere 331G...
Tafe 45DI (A53317)
Tafe 45DI (A53317)
Zero Turn Mower (A55853)
Zero Turn Mower...
