Moving Fishing Kayaks with a Tractor w/ Pallet Forks
   / Moving Fishing Kayaks with a Tractor w/ Pallet Forks #11
Mount a pair of kayak J-bars on each side of the tractor, at an easy lifting height. Make them easily detachable for tractor work.
Bruce
   / Moving Fishing Kayaks with a Tractor w/ Pallet Forks #12
I'd just make a double-wide cradle for them with a single axle across the middle and 26" bike tires. You can load them on the cradle and slide them back and forth to give you neutral fore/aft balance and then you can wheel it by hand with little to no physical exertion far faster than getting the tractor involved. If you must involve the tractor, make it a trailer and tow it. The bike wheels will make it super easy to maneuver inside your barn as well.
   / Moving Fishing Kayaks with a Tractor w/ Pallet Forks #13
I'm with Moss. If you stick stuff way out in front of your tractor there's a lot higher chance, than with towing, that you're going to hit something. Bike wheels would be perfect!
   / Moving Fishing Kayaks with a Tractor w/ Pallet Forks #14
I like the idea of ropes, I'm sorry lines, going from the bow to the forks and from from the stern to the forks. One long and one short with carabiners. You could have the kayaks on the floor in your building and drive the forks over the top. Hook up both lines on both kayaks. Get back on the tractor and raise the forks lifting both kayaks. I realize that the kayaks are 11' long but almost half of that will be under the forks. I like this idea so much I think I will try it with my kayaks.
Great Dane Van Trailer 1989 (A56436)
Great Dane Van...
Set of Heavy Duty Steel Trailer Ramps, 60" Long (A59076)
Set of Heavy Duty...
TANK MANIFOLD (A58214)
2011 JACK COUNTY TANK 130 BBL STEEL (A58214)
2011 JACK COUNTY...
Mower King SSRC72 72" Brush Cutter (A57149)
Mower King SSRC72...
UNUSED IRANCH IREA5 HYD THUMB CLAMP (A58376)
UNUSED IRANCH...
