Moving 100LB Propane Tank with FEL?
   / Moving 100LB Propane Tank with FEL? #31
NFPA 58 ( 2011 Edition ) page 65 section 9.3.2.9 " relief valve in communication with the vapor space" also section 7.2.2.5* valves must be sealed and protected.
   / Moving 100LB Propane Tank with FEL? #32
Before we had a road we'd float 100 lb propane tanks across the lake, usually bringing in 5 or six for the winter.
Never had any problems at all.
We'd crack the valve before connecting to clear any liquid.
One thing we learned was when very cold you could never get usage of the entire contents but come spring there would always be about 1/3 remaining.
We had no choice as there was no electricity on our lake so propane was the only way to run a fridge and provide lighting.
\LOL, plumbing was a little house with the crescent moon cut in the door.
Times have changed as we have a road now and I have my tractor for snow removal.
Actually as an association we built the road ourselves.
There are C3 tanks that have had a fire built under them in order to get some flow.
   / Moving 100LB Propane Tank with FEL? #33
Your correct, less then 45 lb can be in any position an greater then 45 lb must be in vapor space. From 2014 edition
Guess its one of those some fill stations will let you lay them down and others say no. Since trucks normally require at least 100 gallons to be delivered, I'll still have mine filled and haul back laying down in back of the pickup
   / Moving 100LB Propane Tank with FEL? #34
So OP could gang together 2 or 3 40# tanks instead single 100# tank. Then not be concerned about transporting the tank vertical to get filled.
   / Moving 100LB Propane Tank with FEL? #35
I would
#1 make sure the tank is completely full
#2 aim the tank bottom end up towards your destination at a 45 degree angle
#3 Knock the valve off with a 2 pound sledge hammer and that tank will be at it's new home in no time
   / Moving 100LB Propane Tank with FEL? #36
Or buy a couple of 100lb cylinders with multi-valves and have the LP company deliver it. Or buy your own 100 gallon tank and fill it in the summer. Every time you interrupt the fuel source ( changing tanks out / running out of gas ) you are required by code to do a " leak check" to make sure that the system is "gas tight" its not hard to do but it is a specific process with documentation. I cant imagine any insurance company would not be looking for that info if there was ever a fire or other serious claim at that site. I do not think anyone should mess with gas without the proper training and equipment to do it correctly and safely. I have been an LP emergency industry responder for many years and I just shake my head sometimes at what I see or read.
   / Moving 100LB Propane Tank with FEL? #38
I just did this. PG&E power company is now "voluntarily" shutting off power possibly for days during storms-- meaning you might need some serious generator capacity.
I lifted/skidded/slid two 100lb (empty) containers into my dump trailer. With them empty, I could drag/lift them onto the trailer. I transported them upright and strapped one to each front corner of the trailer. Fortunately the guy at the filling station agreed to fill them in place (on the trailer) even though he said he was not supposed to do that.
Getting home, the thought of lifting/skidding those two full tanks off the back of the trailer to unload them was a concern. I hooked a chain through the upper "collar" of the tank, picked it up with the front end loader off the back of the tank, and drove it over to the generator. Worked great Liquid Propane Transportation Service. My small tractor didn't have enough height to do this but my bigger tractor did.
Having done this, I look back at the guy agreeing to fill them in the trailer. Had he not agreed to that, it would have been difficult to get them back in the trailer by hand, as the dump trailer has a high deck. Would probably have had to skid them into the trailer sideways, then grab one end and tip it up once it was inside the trailer.
Yes, using a FEL to move a 100lb propane cylinder is possible. The safest methods include using pallet forks with straps, securing it in the bucket with ratchet straps, or lifting a dolly with the FEL. Keeping the tank upright and moving slowly is key. Some prefer on-site refills for convenience, but if you transport it yourself, ensure it's stable and secure.
   / Moving 100LB Propane Tank with FEL? #39
There is no requirement to keep a propane 100 lb. bottle upright. Just don't let it role around while transporting it.
   / Moving 100LB Propane Tank with FEL? #40
I have taken a 100 pound cylinder in to be refilled several times. Never had it upright, always laid down. No problem what so ever carrying in the FEL bucket while laid down.
2020 CATERPILLAR 299D3 SKID STEER (A51242)
2020 CATERPILLAR...
Informational Lot - Financing (A52128)
Informational Lot...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
2010 CATERPILLAR CM1210106 ROUGH TERRAIN FORKLIFT (A51242)
2010 CATERPILLAR...
2016 JLG ECOLIFT 70 SELF PROPELLED MANLIFT (A51242)
2016 JLG ECOLIFT...
10855 Pumping Unit- ENGINE ONLY (A52128)
10855 Pumping...
