Moving 100LB Propane Tank with FEL?
   / Moving 100LB Propane Tank with FEL? #11
I moved 2 close to empty 100 lb tanks with a FEL a few years ago. I don't have pictures but it was fairly easy to move them on the FEL and keep them upright with straps.
   / Moving 100LB Propane Tank with FEL? #12
I just did this. PG&E power company is now "voluntarily" shutting off power possibly for days during storms-- meaning you might need some serious generator capacity.
I lifted/skidded/slid two 100lb (empty) containers into my dump trailer. With them empty, I could drag/lift them onto the trailer. I transported them upright and strapped one to each front corner of the trailer. Fortunately the guy at the filling station agreed to fill them in place (on the trailer) even though he said he was not supposed to do that.
Getting home, the thought of lifting/skidding those two full tanks off the back of the trailer to unload them was a concern. I hooked a chain through the upper "collar" of the tank, picked it up with the front end loader off the back of the tank, and drove it over to the generator. Worked great. My small tractor didn't have enough height to do this but my bigger tractor did.
Having done this, I look back at the guy agreeing to fill them in the trailer. Had he not agreed to that, it would have been difficult to get them back in the trailer by hand, as the dump trailer has a high deck. Would probably have had to skid them into the trailer sideways, then grab one end and tip it up once it was inside the trailer.
   / Moving 100LB Propane Tank with FEL? #13
The 100#ers are easier to move horizontal as you can use the leverage of the length to put back upright. They are a Bit*** to move vertical by rolling on the edge.. The diameter tends to make them top heavy.
Ron
Propane cylinders should NEVER be transported horizontally. If they are then the liquid propane is in direct contact with the relief valve which is designed to release at a certain pressure set point. ( 250 PSI for ASME 312 for DOT ) if your relief valve opens and allows liquid propane to enter the atmosphere it will expand 270 times settle towards the ground and may find a source of ignition. pickup truck propane tank explosion at McDonald's - YouTube. A 100 lb cylinder can be transported vertically after being hoisted into the back of the truck with the relief in vapor space, the valves protected and it secured.
   / Moving 100LB Propane Tank with FEL? #14
So I'm curious how come every propane powered lift truck in the world has a tank that is mounted horizontal while in use but gets handled vertically every time they are moved or stored?
   / Moving 100LB Propane Tank with FEL? #15
They could be liquid withdrawal tanks or vapor withdrawal tanks that are specific to the use. 100LB cylinders can be purchased with multi-valves and can then be filled on site so that transportation is not necessary.
   / Moving 100LB Propane Tank with FEL? #16
The are easily moved with a good two wheel dolly.
   / Moving 100LB Propane Tank with FEL? #17
You already use it sitting on a pallet, right? Pallet forks on the loader arms! Strap the tank down first ;)
Not sure how they expect a person to heft a filled 100# tank back up into their truck at the filling place. If they have a requirement that the tank not be on the transporting vehicle, they better have a method of lifting it off and back on.
   / Moving 100LB Propane Tank with FEL? #18
It's my understanding that Federal law prohibits transporting them horizontally. http://www.apollopropane.com/pdf/TransportingPropaneCylinders.pdf
I once put a tank onto a plastic totesled and slid it down and unplowed road, controlling it with a rope and making sure to stay out of the way.
I'm not sure I would advise it though.
   / Moving 100LB Propane Tank with FEL? #19
While there are some propane companies that will not fill a 100 unless its upright, I have always been able to find others that will (check your local regs). There is an issue with releasing pressure with the valve, this has to to with over enough time where pressure can build up to unsafe amount. That said, the valve will still release pressure, so it could be just gas (if up right) or liquid (laying down), the pressure is still reduced.
So don't carry it in a enclosed area, and don't put it there and leave it for long periods. Moving it from one place to another using a FEL is no big deal. Takes very little time and doesn't matter to the tank
   / Moving 100LB Propane Tank with FEL? #20
Other option is a pair of 40# tanks and auto switch over regulator. I did here to get rid of the 100# tank and higher priced propane delivery. When one tank is empty it shows a red indicator and swaps to the other tank. Then I can get the empty tank filled while still having gas left.
2013 POLARIS RANGER 800 EFI UTV (A51243)
2013 POLARIS...
2004 Honda Pilot SUV (A50324)
2004 Honda Pilot...
Lot (3) Rolls of Barbed Wire (A50515)
Lot (3) Rolls of...
DROME EXCAVATOR SLIDE ATTEHMENT (A50322)
DROME EXCAVATOR...
2014 JOHN DEERE 35G EXCAVATOR (A51242)
2014 JOHN DEERE...
2002 FREIGHTLINER FL70 DUMP TRUCK (A51406)
2002 FREIGHTLINER...
