Front-End Loader MOUNTING YANMAR TO KIOTI
/ MOUNTING YANMAR TO KIOTI #1
VBROS
dresden, tn
KIOTI CK25 HST
I OWN A KIOTI CK25 HST TRACTOR. I RECENTLY LOCATED A YANMAR FL 650 (SER.# 1292) FRONTLOADER. CAN THIS LOADER BE ADAPTED TO FIT MY TRACTOR?
/ MOUNTING YANMAR TO KIOTI #2
With enough time and fabrication, the Yanmar loader will absolutely fit. The question is how much fabrication will be required. Your CK25 is quite a bit larger than the machines Yanmar usually paired with that loader. It has over a foot more wheelbase and much larger tires. There may not be enough length in the loader from its mounting bracket to the bucket to clear your machine's front axle. It may be too narrow to fit around your engine and transmission housing. The bucket may be too narrow.
My suspicion is that by the time you are finished, you will essentially have fabricated a new loader frame from scratch and simply used the Yanmar's cylinders and bucket, anp perhaps the arms if you reconfigure the bucket.
