mounting eyes for hydraulic cylinderr
   / mounting eyes for hydraulic cylinderr #1
bdog
Elite Member
Texas
John Deere 6130M
I am fabricating something and am going to add a hydraulic cylinder fro a moving piece.
Do I need to make the eyes that the cylinder will pin to myself or can weld on eyes be bought somewhere?
Making them does not seem that difficult but I don't have anyway to drill a 1" hole for the clevis pins and torching one would likely give some unwanted slop.
   / mounting eyes for hydraulic cylinderr #2
I did not know those worked well with thick metal?
I have used them a lot on sheet metal but never anything thick. Depending on the style of cylinder I get I will need the material to be 1/2" to 1" thick. Will those saws work on stuff that thick?
   / mounting eyes for hydraulic cylinderr #4
Weld on eyes, if they could be found, would likely cost more than buying a 1" bit or even taking to a local shop and having them spend 10 minutes and give you a few holes.
   / mounting eyes for hydraulic cylinderr #5
Once the pilot hole goes through, reverse the metal plate.
If you have a cutting torch, you can make an circle adapter and cut some descent holes.
You could make a template and cut the circle.
If you cut smaller than your desired cut, then use a reamer for the finish 1 in hole.
I also did some cad drawings and put them on a thumb drive and had a steel mill cut out the 20 tabs with holes.
I only need two of them. How much could they cost? To make them I would need to go buy the metal to begin with and they don't like selling small pieces. Then I have to cut them to size and shape and grind them smooth. Then drive around town to find a shop to make the holes. They charge me something probably whatever their minimum fee is. More than likely they won't do it while I wait so I have to drop them off and then come back at a later time and pick them up.
Figuring in the time and effort spent on making them myself this way If I could order a couple for even $50 each and have them shipped I would probably come out ahead.
   / mounting eyes for hydraulic cylinderr #7
So a 1" hole then. How thick does the material need to be?
   / mounting eyes for hydraulic cylinderr #8
Just use a good hole saw, run at a slow speed using oil. I would say around 200 rpm's and it well make a nice hole.
1" thick.
I was googling the wrong thing. I was searching "mounting eye" and not having much luck. I searched "clevis mount" and found this. Bumper Clevis Mounts $22.95 for a pair of them.
   / mounting eyes for hydraulic cylinderr #10
Tell us just what you need and maybe one of us could help out.
2019 CATERPILLAR D6T LGP HI-TRACK CRAWLER DOZER (A52705)
2019 CATERPILLAR...
2019 MACK PINNACLE P164T DAY CAB ROAD TRACTOR (A51406)
2019 MACK PINNACLE...
2018 Bobcat T595 (A47384)
2018 Bobcat T595...
2020 CATERPILLAR 259D3 SKID STEER (A52705)
2020 CATERPILLAR...
2003 Atlas Copco 75kW ABB Rotterdam 220psi Air Compressor (A52377)
2003 Atlas Copco...
