Mounting a Tilt Dump MCS on a JD445
/ Mounting a Tilt Dump MCS on a JD445 #1
bjorn773
Roscoe, IL
Kubota L2250
I purchased a leaf collector yesterday on marketplace. The best I can tell is that it's the JD Tilt Dump MCS. This particular model has the gas engine off to the side to run the blower, not the pto driven blower. It was mounted on an X730 I believe, so the included brackets are not quite the same. I am hoping that I can mount it to my 3 point hitch by fabricating an adapter. Would there be any concern with that weight on the 3PH? I believe it's rated for 758#. Please advise and thank you!
/ Mounting a Tilt Dump MCS on a JD445 #2
Your L2250 should handle the weight just fine. If not, put a few suitcase weights on the front bumper.
/ Mounting a Tilt Dump MCS on a JD445 #3
Your 445 should handle that but like big tiller states you may need some front weights when that bagger is full of wet grass or support caster wheels on the rear.
Thanks. It will be going on the JD445 as I don't have a mowing deck for the L2250. I've got 6 suitcase weights and a front weight bar, so should be good there.
2022 John Deere R4023 (A60462)
2022 John Deere...
2018 Ford Escape AWD SUV (A59231)
2018 Ford Escape...
PLANTER, PARTS (A60430)
PLANTER, PARTS...
2022 CATERPILLAR 249D3 SKID STEER (A60429)
2022 CATERPILLAR...
(APPROX.64) 2X6X8 NO.2 PRIME LUMBER (A60432)
(APPROX.64) 2X6X8...
UNUSED RAYTREE RMBD72-72" HYD DRUM MULCHER (A60432)
UNUSED RAYTREE...
