Disc Harrow mound soil, how do I?
/ mound soil, how do I? #1
Glenn K
Australia
Kubota BX2670
I am trying to make raised beds to grow blue berries some at 3m (10') and others at 2.4m (8') centres.
I have got the use of a merbein plough and set it at 2.4m which is as wide as it will go but at this width it does not move the soil to the centre. I was thinking if I made some sort of shaper to drag the soil into a mound shape it should work from here but I have never seen such a thing. Does anyone have a photo or link to a moulder? Or any other ideas.
/ mound soil, how do I? #2
612690-Disc Hillers Rear small.jpg607737-Disc Hillers Left small.jpgYour discs (only need 2) are too far apart. I made raised rows with each disc right behind the rear wheels, which are right at 4' at their outer edge.
Ralph
Thanks Ralph but if it was set at 4' it would leave 4' (with 8' spacing) or with 10' spacing 5' of unmoved soil between rows. So I would sort of have twice as many rows as I want. Or am I not following you correctly?
Would a second run with what I have work?
/ mound soil, how do I? #4
Glenn, I think you need to make a pass or two like you have, laying out the rows. Then adjust the disk to a narrow setting and make another pass or two to complete the hills.
/ mound soil, how do I? #5
I agree you will want everything disked well before making the rows. Even if a second pas works you will have your plant routs trying to grow through undisturbed compacted soil. For the hill making pass, can you move the disks closer together?
/ mound soil, how do I? #6
I got 20 raised rows within a 75' garden length. Each raised row is short of 4' from the next one by about the width of a rear tire, with the discs as shown behind the wheels. I could just spin a 180 using my brakes and do the next row with the tractor tires running in the track made by the disc.
Ralph
/ mound soil, how do I? #7
I cut up the entire garden using 9 cultivator tines mounted on the same bar the discs are mounted on. It's an old JD M tool bar. The cultivator tines are called "soil rippers". Then I removed the tines and mounted the 2 big 20" discs.
Ralph
I first used a chisel plough then a rotary hoe and the soil is sand so I just need the rows formed. I will try a second run in a couple of days.
Will try a second run and see how I go, thanks.
/ mound soil, how do I? #10
Are you looking for a bed shaper?
Buckeye Tractor Online Catalog Page 03-01 Bed Shapers
Another way to do this in more of a rounded mound shape is with a toolbar and a set of "hillers".
Google for Bayou Gardener or Everything Attachments to see an example. I use the single disc type hiller [as opposed to the gang of 3]
Angle of disc and distance between them depends upon many things; soil type, moisture, probably many more factors.
My toolbar [from Stevens Tractor] is their six shank model, with hillers [also called hippers in some parts of the country] and what they call a row opener.
This is an extension off the back of the bar with a shank holding a cultivator tip to make a trench in the mound you just made with the hillers.
Buckeye makes all sorts of gadgets for the market/specialty farm.
I do not own any of their stuff since I had already found what worked for me.
If I ever go into full time specialty crop, I will probably get a bed shaper & maybe a mulch layer attachment for it.
Hope that was of some value to you.
This was a huge help thankyou now I can search hillers, row hippers and bed shapper. Here they are called Merbein Ploughs and Moulders which doesn't find a lot on the net.
/ mound soil, how do I? #12
Your close up of the row shows that you still have clods of dirt that the disc is pulling up. I use a tiller set to full depth to till the area I want to make rows in. A two disc hiller then does a great job because the soil is loose enough to move. I think you will achieve good results if you move the discs toward the center a bit. Experiment. Till the soil until you don't have clods, move the disc in a bit and leave space between rows to achieve the desired number of rows for the area.
/ mound soil, how do I? #13
IMG_0071 - Copy.JPGGlenK:
Here are some photos of a hiller I bought last year. I am sure you can put one together by your self. You don't need that large shoe (sweep) in the middle. It just makes a center groove on the hill for like planting potato's.
You Aussies were realty great to us Yanks during the Viet Nam War. A number of nurses from my hospital (95th. Evac)took there R&R in Australia and were treated like family with so much warmth and kindness. You are great people and I hope you can keep the invasion from the North out. We could come down under and help.
Rocky
Unused 2023 USA Manufacturing Hydraulic Thumb Excavator Attachment (A66734)
Unused 2023 USA...
GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A67714)
GENERAC MOBILE...
More Info coming soon (A66738)
More Info coming...
2025 Swict 66in Bucket Skid Steer Attachment (A66734)
2025 Swict 66in...
2014 MAC FLAMELESS HEATER TRAILER (A67714)
2014 MAC FLAMELESS...
2018 WILDCAT (A67714)
