Motor specs on the 48" T-8 brush cutter?
   / Motor specs on the 48" T-8 brush cutter? #1
KentT
Elite Member
Sevierville, TN
1993 Power Trac 1430 w/Kubota diesel engine
Anyone know what the specs are? Tried searching to no avail...
Mine is leaking at the shaft seal, after years of abuse and needs to be rebuilt or replaced. Likely could replace it from Surplus Center as cheaply as I could have it rebuilt. TIA...
   / Motor specs on the 48" T-8 brush cutter? #2
If I recollect right, it was something like a 3 cuin motor.
With 8 GPM, speed = 616 rpm
---------------torque = 1432 in lbs or 119.3 ft lbs
Will develope about 14 HP.
Surplus Center
Thanks, JJ.
   / Motor specs on the 48" T-8 brush cutter? #4
Danfoss: 3 cubic inch per rev.
2017 Ford Explorer SUV (A56859)
2017 Ford Explorer...
2018 DODGE RAM 2500 (A58214)
2018 DODGE RAM...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A55973)
2013 Ford F-150...
2020 DRAGON ESP...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
