Motor specs on the 48" T-8 brush cutter?
   / Motor specs on the 48" T-8 brush cutter? #1
KentT
Elite Member
Sevierville, TN
1993 Power Trac 1430 w/Kubota diesel engine
Anyone know what the specs are? Tried searching to no avail...
Mine is leaking at the shaft seal, after years of abuse and needs to be rebuilt or replaced. Likely could replace it from Surplus Center as cheaply as I could have it rebuilt. TIA...
   / Motor specs on the 48" T-8 brush cutter? #2
If I recollect right, it was something like a 3 cuin motor.
With 8 GPM, speed = 616 rpm
---------------torque = 1432 in lbs or 119.3 ft lbs
Will develope about 14 HP.
Surplus Center
Thanks, JJ.
   / Motor specs on the 48" T-8 brush cutter? #4
Danfoss: 3 cubic inch per rev.
2021 John Deere 331G Track Loader (A53342)
2021 John Deere...
New/Unused Quick Attach Auger with Three Bits (A51573)
New/Unused Quick...
NEW Wolverine Skid Steer Drive and Augers (A53002)
NEW Wolverine Skid...
2015 DODGE RAM...
2006 Magnolia Dry Fertilizer Tender Trailer - Dual Stainless Compartments, Hydraulic Doors (A53472)
2006 Magnolia Dry...
2006 International 9400i (A53472)
2006 International...
