Most useful implements?
   / Most useful implements? #141
The implement I’ve gotten the most value out of is my 3-point chipper. No more weed choked brush piles and no more burning. Worth every cent and then some.
   / Most useful implements? #142
Just pick up some gravel or crushed rock. Dump some around the post and wiggle it a bit. The rock/gravel is self tightening. The more you wiggle the post the tighter it gets. I learned this from the power companies in our area. They only set power posts with crushed rock.
Yep. The wiggle method works great with sackcrete as well. Just pour it in (dry), wiggle the post until it tightens up, check level then pile dirt around the post and tamp it down.
   / Most useful implements? #143
Large square bales are more popular in the PNW because of the export market. They take a 1000 lb. square bale, mash it to 1/3 the original volume with a high pressure press, then pack the results into shipping containers. There is a big export market for wheat straw and grass straw, not crops you grow a lot of in Missouri. I think there may be some shipped down the Big Muddy to the Middle East, but shipments to East Asia head right across the Pacific.
Yeah, California is outlawing round bales…
because the cows can’t get a square meal 🤣
   / Most useful implements? #145
   / Most useful implements? #147
Try it. Might even work in float and add weight if needed.
With the independent suspension on the Toolcat I was able to put some down pressure on the gate.
Only thing is,I'd have to purchase one to try it. If it's a flop it's an expensive experiment. If it works well it's pretty cheap for what it will do!
Might give this a whirl. Should be easy to transport on my trailer with my tractor and other implements when I go somewhere. I've taken the 8x8 drag a few times and it's cumbersome to transport to say the least.
   / Most useful implements? #150
My flail mower in the Spring, summer and fall...Snow blower in the snow season.
Although I haven't had to use them yet, I expect my pallet forks will be very handy as well.
Although only used a few times a year, the Woodmaxx wood chipper is invaluable after trimming some trees and low hanging branches
STAINLESS STEEL WARMING STATION ON WHEELS (A58374)
STAINLESS STEEL...
Diamond C Trailers 26ft T/A Flatbed Tilt Trailer (A55787)
Diamond C Trailers...
2019 PETERBILT PB520 GARBAGE/SANITATION TRUCK (A58375)
2019 PETERBILT...
LOUISVILLE 6' ROLLING LADDER STAND (A58374)
LOUISVILLE 6'...
2018 Volvo MCT 110C (A55272)
2018 Volvo MCT...
(2) 4"x30' NYLON STRAPS W/RATCHETS (A52708)
(2) 4"x30' NYLON...
