Comparison Most powerful tractor w/ 48" width
/ Most powerful tractor w/ 48" width #1
weesa20
North Carolina
Wondering what the most powerful mainstream manufacturer tractor is with 48" width. I know the TYM 273 was 27hp with 48' stance, others with more HP?
/ Most powerful tractor w/ 48" width #2
A Deere 2720 is 47.1 inches at minimum spacing and is about 31 hp.
How much HP do you need? If you look at Vineyard tractors, most of ther big names have a 48" version with 60-100 HP
NH: TN75VA or TN95VA
Deere: 76F
Kubota: M6040, M7040 and M8540 Narrow
Can one really have enough?
I was not thinking about including special use machines...looking more at the standard CUT market.
/ Most powerful tractor w/ 48" width #6
Kubota has a narrow version B2320. But that's only 23hp.
/ Most powerful tractor w/ 48" width #7
The JD 2720's I have measured are actually closer to 54" as are the larger B series Kubota's like the B3200. The B2920 is probably closer, and has 29 Hp, but even they may be 49" or so. I use 48" attachments with my B2620, and they work fine, but I can't say for sure that the traactor is actually under 48".
/ Most powerful tractor w/ 48" width #8
Most people set the wheels wider but a minimum width setting yields 48" with the Deere 2720.
/ Most powerful tractor w/ 48" width #9
The narrow setting for the 2720 is 48 inches, most people would have them set wider for stability.
2004 Winnebago Adventurer 38G 38ft. Class A Motorhome (A59231)
2004 Winnebago...
2000 CATERPILLAR 988F SERIES II WHEEL LOADER (A64279)
2000 CATERPILLAR...
Adams Weight Hopper (A63688)
Adams Weight...
2007 Komatsu WA200-5 (A64047)
2007 Komatsu...
2860 (A56857)
2860 (A56857)
Cat CB24B (A60462)
Cat CB24B (A60462)
