Backhoe Most common failure of 3PH mounted backhoe?
   / Most common failure of 3PH mounted backhoe? #11
</font><font color="blue" class="small">( Here is a shot from the right side of the tractor....you can see how the gray bracket attaches to the loader frame and extends back to the rear end...
)</font>
Cool, thanks !
Yup, I just went and looked - I've got the same brackets on my B2910. However, these brackets were installed on the tractor when I bought it with the 402 FEL (but WITHOUT the BL4690B backhoe ... which I added later) Based on that, I'd say that these brackets are actually part of the loader subframe.
In reality, they could be a sort of combo loader/backhoe subframe and may be another reason (besides weight and counterbalance) why Kubota says that a FEL is required for a Kubota backhoe on this tractor.
I think Neil is correct in his assessment - it isn't really a subframe that attaches directly to the backhoe, but it does provide additional strengthening of the frame and essentially provides the functionality that a subframe would (more or less.)
   / Most common failure of 3PH mounted backhoe? #12
</font><font color="blue" class="small">( This is a shot of the brackets that I was given, that were removed when the backhoe was installed... )</font>
Yup - I got those too when I initially picked up the tractor.
   / Most common failure of 3PH mounted backhoe? #13
I guess I just assumed that those longer brackets were put there as the result of the backhoe being installed... /forums/images/graemlins/blush.gif
Sounds like rswyan may have hit the nail on the head if they were there with his B2910/loader before the backhoe came into the picture... /forums/images/graemlins/smile.gif
Husqvarna Riding Mower (A56857)
Husqvarna Riding...
2015 Lincoln MKZ Sedan (A56859)
2015 Lincoln MKZ...
Le Roi 80-Gallon Air Compressor, 220 Volts (A59076)
Le Roi 80-Gallon...
2013 Ford Edge (A54815)
2013 Ford Edge...
2013 GMC Silverado 3500HD Flat bed (A55973)
2013 GMC Silverado...
2005 Chevrolet C4500 Altec Bucket Truck (A56858)
2005 Chevrolet...
