more tiller ????
/ more tiller ???? #1
runningbird
Gisela, AZ
yanmar 1110d ,fx28d
how deep are you all tilling. once I get about a 9" down the angle on the U-Joints gets too steep and starts to bind. any idea's????
thanks mark
my tractor is a y2000 the tiller is a 1300, but also has 1300-1700 on it.
/ more tiller ???? #2
9" is getting pretty deep for a tiller. I typ limit my depth to the 6-8" range. How you have your top link set will impact the angle of the U-joint. Maybe you need some adj on the link. My tiller still has the decals on it and it give a dim for the top link length. Sorry don't know that dim right now.
/ more tiller ????
thanks for the help. I did lengthen the top link yesterday and it helped. my top link is only about 4" at the most and from a picture posted yesterday it looks like it may be to short. I may search for a longer one in the future. I have never used a tiller before I just thought I should be tilling deeper, I must have been wrong and will keep it more shallow now.
thanks
mark
/ more tiller ???? #4
I agree that 9" is pretty deep..... At about 7-8" I'm plowing with my gearbox's..
/ more tiller ???? #5
That is the extreme most you can reasonably till with it. I realize this is more gardening (assuming you're tilling for a garden) than tractoring, but why so deep?
/ more tiller ???? #6
Took a look at the decal with pert info. Assuming you have the correct top link assembly, the proper dim is 205mm/8.06". Decal lists different top link assy depending upon tractor model. The 205mm is proper length for the tractor models cloest to your model #.
Fortunately for me my top link mount lists tractors it designed for and my model # is included. My link is 211mm/8.3"
/ more tiller ????
thanks for the help. my top link is adjustable and will reach 8.25" center to center when it is extended. So maybe I do have the correct link and I'm just tilling to deep.
thanks
mark
2001 MACK VISION DUMP TRUCK (INOPERABLE) (A67714)
2001 MACK VISION...
2013 CHEVROLET TAHOE (A66091)
2013 CHEVROLET...
2020 VOLVO VNL760 SLEEPER TRUCK (A59914)
2020 VOLVO VNL760...
2013 MACK CHU613 WINCH TRUCK (A67714)
2013 MACK CHU613...
12ft T/A Flatbed Utility Trailer (A64553)
12ft T/A Flatbed...
D8 CAT U-Blade (A68134)
D8 CAT U-Blade...
