3-Point Hitch More than a hiccup
   / More than a hiccup #1
cpocobb
Ga
Branson 3510
My Branson 3510ii has had a hiccup (bounce) in the 3 point hitch for quite some time, but today it became a major issue. I seem to have lost some of my hydraulic power, and if I have the hitch under load and use the loader, the hitch drops slowly. As soon as I stop using the loader, the hitch returns to the up position. I also have a new noise coming from the rear of the tractor - a hissing sound that sounds like fluid leaking through a valve. I figure I’ll have to rebuild the rock shaft piston, but suspect there could be more going on. Any help will be much appreciated!
   / More than a hiccup #2
How about some history: Age and hours on tractor, last main sump oil and filter change.....type of oil used, condition of oil removed, usage schedule like seldom, daily, winter pushing snow only....... Had the oil analyzed?
   / More than a hiccup #3
I believe this is a common issue in this model. The piston seals will leak and will start bouncing as the position control valve tries to compensate of the drop. If you leave it long enough without getting new seals, the seals will get worse and the valve can barely compensate for the leakage through the piston, then if you use the loader valve which takes all the flow of the pump, the 3 point will drop.
The sound you hear, might be the fluid going through the piston.
   / More than a hiccup #4
The really bad thing about that fluid flowing past the seals is that it can cut a groove in the cylinder if not taken care of.
If you are going to use the tractor awhile before working on the 3 point lower the control to all the way down.
Good luck
I replaced the seal in the cylinder today, and all seems to be good. Haven’t put it under load yet, but the old seal was done. Part of it was missing.
   / More than a hiccup #7
Good to hear, hope it holds.
2007 INTERNATIONAL 4200 SBA 4X2 DUMP TRUCK (A51243)
2007 INTERNATIONAL...
2014 Ford Taurus Sedan (A50324)
2014 Ford Taurus...
2025 Future Stump Grinder Mini Skid Steer Attachment (A50322)
2025 Future Stump...
2018 Bobcat T590 Compact Track Loader Skid Steer (A50322)
2018 Bobcat T590...
2018 WACKER NEUSON CORPORATION DBA WACKER NEUSON LTV6 LIGHT TOWER (A50854)
2018 WACKER NEUSON...
2019 Ford Explorer AWD SUV (A50324)
2019 Ford Explorer...
