More radio stuff
/ More radio stuff #21
I had a simple Chryco AM/FM radio. No cassette or anything. That thing had a really HOT AM receiver.
A company called C Crane (sp?) apparently makes such radios.
/ More radio stuff #22
For AM generally a long wire works if oriented properly. (like spread your arms facing the station)
Yes and no. If you're using it as a dipole (ie downlead is tapped from the center of the longwire) you are correct. If you take the feed from the end of the wire, it's most sensitive along the length of the wire, and quite effectively nulls from the sides.
Many years ago I had 2 longwire AM antennas, 90º to one another with a switch going to my receiver. In many instances there'd be a completely different station when I'd switch from one antenna to the other.
/ More radio stuff #23
Here is my reciever.... It transmits too from 1.8 to 54 Mhz. :)
/ More radio stuff #24
As I remember from my childhood crystal radios, a long wire works well for an AM antenna, and you need a ground on the other end of the coil to get the best signal. Modern radios have all sorts more amplification, but the signal still makes the difference.
Crystal Radio Circuits
2023 Unused Unverferth Air Top SPTATV001B 200 Gallon T/A Towable Boom Tractor Sprayer (A66734)
2023 Unused...
2019 INTERNATIONAL MV607 REEFER TRUCK (A67714)
2019 INTERNATIONAL...
2014 Ford Escape AWD SUV (A66738)
2014 Ford Escape...
6 1/4 INCH OD 90 DEGREE ELBOWS (A68842)
6 1/4 INCH OD 90...
2016 Chevrolet Tahoe Multipurpose Vehicle (MPV), VIN # 1GNLCDEC0GR387273 (A66738)
2016 Chevrolet...
2022 CHEVROLET TAHOE (A66091)
2022 CHEVROLET...
