More radio stuff
/ More radio stuff #21
I had a simple Chryco AM/FM radio. No cassette or anything. That thing had a really HOT AM receiver.
A company called C Crane (sp?) apparently makes such radios.
/ More radio stuff #22
For AM generally a long wire works if oriented properly. (like spread your arms facing the station)
Yes and no. If you're using it as a dipole (ie downlead is tapped from the center of the longwire) you are correct. If you take the feed from the end of the wire, it's most sensitive along the length of the wire, and quite effectively nulls from the sides.
Many years ago I had 2 longwire AM antennas, 90º to one another with a switch going to my receiver. In many instances there'd be a completely different station when I'd switch from one antenna to the other.
/ More radio stuff #23
Here is my reciever.... It transmits too from 1.8 to 54 Mhz. :)
/ More radio stuff #24
As I remember from my childhood crystal radios, a long wire works well for an AM antenna, and you need a ground on the other end of the coil to get the best signal. Modern radios have all sorts more amplification, but the signal still makes the difference.
Crystal Radio Circuits
PORTA POTTY (A68842)
2017 CATERPILLAR 926M WHEEL LOADER (A65056)
2017 CATERPILLAR...
(INOP) LAYMOR SM300 RIDE-ON SWEEPER (A65054)
(INOP) LAYMOR...
GENERAC MOBILE PRODUCTS MLT6S LIGHT PLANT (A67714)
GENERAC MOBILE...
2021 DITCH WITCH HX30G VACUUM TRAILER (A63276)
2021 DITCH WITCH...
2012 KENWORTH TRIAXLE BODY LOAD (A67714)
2012 KENWORTH...
