More proof I am an idiot
   / More proof I am an idiot #22
Thanks for sharing, I can relate about how fast things go sideways. Not that it would have helped, but are your chains normally that loose?
All the best,
Peter
All the best,
Peter
My chains are toast. They are paper thin and I am just trying to nurse them until spring when Tire Chains go on sale. As for tightenss, I have never really tightened mine that much. We are pretty clay up here, so very slippery. A few of the loggers told me to run my chains loose as having them tight only helps when you are going fast. They said this would help throw mud if they are loose. Dunno...
   / More proof I am an idiot #24
Hmmm. I have nothing but clay. I run my chains tight, and FWIW they don’t seem to clog. I am using Ken’s diamond chains.
That said, I don’t go out on slopes during the winter as the clay soil here has no integrity and everything slides. The tractor, the cows, me.
All the best,
Peter
   / More proof I am an idiot #25
Also having them loose makes them way easier to get them on. I had my annual reminder of that fact last night when I chained up (mine are tight), thinking that maybe I would have to plow this morning. Not yet, but it is still snowing.
   / More proof I am an idiot #26
In the summer I was cutting brush and watching for rocks at the mower, didn't realize the size of one that high centered the machine. Thank God the underside has no fragile parts like most tractors.
   / More proof I am an idiot #27
I've done that on a few logs. I usually just push down on the implement and back off. Only once in 19 years did I get stuck when I dropped it off a hidden log on a hillside that had built up soil on the top side. It was just like a high step. Didn't have enough down travel to push myself off. Had to make the hike of shame and get a chainsaw. :laughing:
   / More proof I am an idiot #28
That's one of the best things about a Power Trac, the smooth steel plate underside. I was using my Antonio Carraro in high ferns and ended up with a rock under the engine oil pan. I went and got the 310 John Deere and lifted it off, didn't want to risk further damage. Now I aim the tires for the rocks, makes for a lousy ride.
   / More proof I am an idiot #29
When I see a rock, I aim my backhoe at it, dig it out and usually put it in my creek in washout areas. Before I got my backhoe, it was pick and shovel which was no fun as some of them could be quite large with only the tip exposed.
   / More proof I am an idiot #30
My land is like a quarry blast site with some topsoil mix in. If you dig out a rock, there will be 2 more under it.
   / More proof I am an idiot #31
You need some rocks around the edge of that pond . Kevin .
M5040 you need to experience tree wrap then you are a true pt owner. I did one that somehow got me around a 14 inch alder that was so bad I had the tree jammed between the engine cover and the rops. Had to start cutting the tree down by standing on the roof.
   / More proof I am an idiot #33
Feel free to add to the list....
PT Pucker - check
Tree wrap - check
Slide downhill sideways against a fence - bucket list
Throw dirt on lap with FEL - check
Make air hose pass-through port on side of garage with tooth bucket - check
Operate QA before disconnecting hydraulic hoses - check
Try to operate QA without connecting hydraulic hoses - check
   / More proof I am an idiot #35
That low COG sure makes a difference!
That is why many of us own PTs...:laughing: We are big :fan: :fan: of low COG.
Just trying to stay safe while getting the job done.
   / More proof I am an idiot #36
It is amazing how much snow plowing you can do sometimes before you realize you did not engage the hydraulic quick attach tabs. I actually tore a plow hose one of the times I did that. Makes up for my not having done Moss' airline pass through hole nor the fence. I can check the other boxes. I am sure there are plenty of other boxes I can check but they are just not coming to mind at the moment.
Ken
2014 JLG 6042 TELESCOPIC FORKLIFT (A60429)
2014 JLG 6042...
2006 KAWASAKI BAYOU 250 ATV (A60430)
2006 KAWASAKI...
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A61306)
2017 Yale GLC050VX...
Caterpillar 2PD5000 5,000LB Diesel Forklift (A56857)
Caterpillar...
2019 International WorkStar 7300 4x4 Altec AA55 56ft. Insulated Bucket Truck (A60460)
2019 International...
Dodge Charger (A56859)
