MossRoad
Super Moderator
- Joined
- Aug 31, 2001
- Messages
- 66,200
- Location
- South Bend, Indiana (near)
- Tractor
- Power Trac PT425 2001 Model Year
You crack me up.:laughing:
Thanks! I'm here all week. Try the veal, and remember to tip your servers.
Thanks for sharing, I can relate about how fast things go sideways. Not that it would have helped, but are your chains normally that loose?
All the best,
Peter
A few of the loggers told me to run my chains loose as having them tight only helps when you are going fast.
That's one of the best things about a Power Trac, the smooth steel plate underside. I was using my Antonio Carraro in high ferns and ended up with a rock under the engine oil pan. I went and got the 310 John Deere and lifted it off, didn't want to risk further damage. Now I aim the tires for the rocks, makes for a lousy ride.
You need some rocks around the edge of that pond . Kevin .When I see a rock, I aim my backhoe at it, dig it out and usually put it in my creek in washout areas. Before I got my backhoe, it was pick and shovel which was no fun as some of them could be quite large with only the tip exposed.
That low COG sure makes a difference!
At least you need more proof. My wife would say she has enough already.
